Question about Philips 60PP9352 60" Rear Projection Television
Theres is a wave in any writting on the screen
I have tryed using factory settings for the color... and when I try sitting the converge manually the cross hairs are all over the place. Red / Green / Blue some (+) are all over the place. Help if you can !!! Thanks, Jim
  • Philips Master
  • 3,459 Answers
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Posted on Jan 26, 2009
Hitachi 53udx10b screen is dark, very blue and red. there is a red wave across the top of the screen. there is a blue "ghosting" of any text on screen.
The tv have a problems known as a convergence picture problems,it is dead.Tv set have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead to causes all these problems.Now the tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set convergence pictures promblems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Hitachi 43UWX10B 43" Rear Projection...
The picture all of a sudden became blurred , color convergence is not aligned and there is a pink wave at the top left of the screen and a green wave at the bottom of the screen. When the color is adjusted...
Tv have convergence problems,it dead.Colors lines R,G,B don't aligned.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead,these parts must be replaced to solved the tv pictures covergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-43HT20 43" Rear Projection...
Our 7 year old Sony TV KP-51W5510 has the following problem. Picture has 2 colors, writting has 2 colors the skin tone has 2 colors, writting on the screen will show 2 colors black and red in shadows pls...
a ladha,
You have lost the convergence circuitry. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will explain the problem, tell you where to get parts and explain how to do the repair.
Thanks for using FixYa and for the great rating!!
hardrocko
Sep 12, 2010 | Sony KP-51WS510 51" Rear Projection...
JVC- red wave on screen and letters doubled
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 12, 2009 | JVC AV-48WP74 48" Rear Projection...
I have a blue wave on my screen
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in or warped.
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Jan 28, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Picture shadowing and waving pictures
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 19, 2008 | JVC AV-48WP74 48" Rear Projection...
Too much red!
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
Oct 08, 2008 | Hitachi 53SDX20B 53" Rear Projection...
Wave at bottom of screen with green and pink shadows
  • Screen looks 3D
Feb 17, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Problem with color
Replace convergence STK IC's,then realign to factory spec using service literature fo info.
Sep 29, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Hitachi 53FDX20B
If you have a color (red, green or blue) that is bowed inward from any side, then one of your convergence IC's has cracked loose or burned out. There is no way to fix that manually - the IC and possibly a resistor must be resoldered or replaced, and that should be handled by someone experienced in repairing and realigning convergence circuits.
May 06, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
