Question about Dell Dimension 4600 PC Desktop
Wont boot up
When I installed a game on my computer and rebooted it, it would turn on but the blue led power button doesnt turn on and the screen doesnt come on. Took it to get looked at and they ripped me off by saying it was the power supply and threw my old one out. Is it the motherboard??
  • 116 Answers
You need a new power box
Posted on Jan 09, 2009
How do I solve a problem with starting up windows in my hp pavilion g6? Whenever I start windows a blue screen appears and the computer restarts.
Sounds like your hard drive has either failed, come disconnected, or someone performed a full format of the drive which wiped out the partitions or the boot sector of the drive. Worst case you will need to replace drive and purchase reinstall disk from hp. Best case you will only need to purchase reinstall disk from hp. If you do need a new drive, I recommend purchasing it from hp directly, as it will already be prepared with hps proprietary boot configuration files which must be present for hardware to be recognized by system bios.
Dec 31, 2016 | HP Computers & Internet
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
My toshiba at200 table 10.1 wont turn on
1. When you press the power button to turn it on, do you see any thing on screen, like the toshiba boot up screen or something like that. Or is it completely blank (black color) always.
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). This is important to confirm.
3. Also, when you press power button, do you see the LED lights on laptop blinking or solid green (which ones are in blinking/solid) and do hear any sound ? Or do you feel that your laptop doesnt even try to boot.
4. Can you hear any Beeps when you try to turn on the computer. If yes, what is the sequence of those beeps.
Continued......
If you answers are -
1.
blank
2.
no image
3.
only the satellite light is blue, the powercord is blue and the battery is blue
4.
no noise
Please do the following carefully and let me know result :
1. Shutdown and Unplug your laptop.
2. Remove the battery from the laptop.
3. Wait 2-3 minutes
4. Now press ON (power button on laptop) for 1 minute
5. Then release the finger and wait one more minute.
6. Now plug in the power cable (dont insert battery yet) and press ON button.
7. Did your screen start working now ? (do you see windows loading)
Jan 04, 2015 | Video Game Consoles & Games
Laptop wont reboot
Hard Boot - Press the power button till it shuts down. Not an uncommon problem. It's just Windows.
Oct 07, 2012 | Computers & Internet
I install windows xp profetional in g62_b39se it installed compeletly but when insatll completed, an blue screen apeared whith stop massage
Power on Laptop & Click F8 Button then Safe Mode Menu Visible Select "Disable Restart After System Failure" Then U Wacth And Reply Error Msg And Error Code Fully.
Best Of Luck
May 07, 2011 | Computers & Internet
Hi, I have a tosiba satelite laptop. I tried installing the recovery disc and the computer doesnt do anything.Thats the first problem.Im sure there are several viruses on this computer, so thats what I...
hi there!
first of all check the power plug, then turn it on as usual and see if there is any sign of activity(Hardddisk LED, CD-ROM LED)
If there is not, the hardware is broken and u should start worrying.
In that case, take it to nyour hardware retaileer or sell it marked 'Broke!'
on ebay
else
first check in BIOS
(press F1 or Del button when booting, before the windows screen)
- if the CD/DVD-drive is set as first boot device, if not so, change it to 1st, 2nd should be the harddisk.
Then insert original CD of the Windows version u are using, now boot from CD and DO NOT INSTALL Windows but quit the Program by repeatedly pressing F3. Now you should be able to access your harddisk as before.
IF that does not work, take out the CD, reboot without it.
Lucky this time?
Any error messages u see, write down and conme back to fixya to let me help u...
C U soon?
Jan 21, 2010 | Toshiba Computers & Internet
Black screen after turn on
That "Blue Screen" is also known as "Blue screen of Death".
The problem is due driver compatibilty or unstablity.
Try to boot your system to "Safe Boot" by pressing F8 during startup.
Select "Last know good Configuration that works"
Check if it can take you to desktop.
Unstalled the wi-fi driver and reboot.
If the above procedure fails, again
Select "Safe boot"
Now create a restore point  and download the lastest version of your WI-Fi driver and installed.
This should work fine.
Otherwise Backup all your important data from your hard drive (mainly opearting system file installed drive usually C:\) and go for a new Installation.
Dec 28, 2009 | Acer Aspire One PC Notebook
My zen's screen wont turn on
i'm assuming you pushed the reset button at the bottom already. does it seem like it is booting (does the hard drive spin, the head move?) if nothings moves or spins i'm assuming you have a defective logic board. there is a creative zen repair guide that shows you how to do that, the part is on ebay.
Apr 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
Blue blank screen
Try inserting the Mac OSX installation DVD and while booting hold down the alt button. Then select the DVD to boot from it and try to use repair options and disk utility to check the installatio/harddrive.
If this doesnt help, report back =)
Jan 03, 2009 | Apple iBook G4 Mac Notebook
Dell Dimension 4600 PC Desktop Logo
27 people viewed this question
Alun Cox
