Question about Vivitar V-2200GX Tripod
Vivatar Tripod V3000 Camera Attachment Adapter for Nikon D80
I need an adapter for Mounting my Nikon D80 Camera to the V3000 Tripod
  • 24 Answers
Try www.tripodquickrelease.com They have that exact model listed and the plate sells for $16.99
Posted on Jan 30, 2009
Sony DSC-H20 1/4 inch Tripod adapter
There is no way to fix it. You should go to nearest Service centre and change the Camera body part.
Best wishes
Mar 16, 2012 | Sony Cyber-shot® DSC-H20 Digital Camera
Old vivitar lens to adapt to a new digital camera
The nikon d80 you pointed out is a solid good camera. Id suggest buying it, if you are sure your lenses fit, didnt bother to check But I know Nikon is the way to go!
Mar 28, 2008 | Cameras
Vivitar screw mount lens, Nikon D-80 camera. Is there an adapter for this?
The M42 mount was used by several camera manufacturers, most notably Pentax. Nikon is not one of them.
Vivitar made many lenses with a T-mount. This consists of a screw mount on the lens and a suitable adapter, depending on the camera body. This allows a lens to be used with different cameras simply by changing the adapter.
If your lenses are T-mount, then yes, there are adapters available. One source is here.
Be aware that you'll probably lose any metering capability when using any lens with this adapter. You'll have to use a separate light meter or else view the resulting picture on the display and adjust the exposure appropriately.
Dec 22, 2011 | Nikon D80 Digital Camera
I am looking for advice on how to mount a Ball Head on the plate of a regular tripod, So far I have not found a Ball Head that has the same size thread in the bottom. Is an adapter available as a solution....
The bottom threads on most tripod heafs are 3/8", but some are 1/4"/ The mounting screws on MOST tripods are 3/8", but I have seen `/4" (especially on monopods. IF:
tripod=3/8 head = 1/4 need mounting plate 3/8 female to 1/4 male
tripod = 1/4 head - 1/4 nothing
tripod 3/8 head 3/8 nothing'
tripod 1/4 head = 3/8 there is an adapter/reducer that screws into the 3/8
' female and reduces that to 1/4"
Feb 20, 2011 | Photography
Nikon 70-200mm Tripod Mounting Question
There should be a mount that attaches around the barrel of the lens with a flat part that would allow you to screw that to your quick release plate. The flat part usually have several screw holes so you can mount the quick release plate for or aft for better balance. These mounts are removable so it may have been taken off.
Nov 22, 2009 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
Hi, I need to position my camera upside down so I can take photos, numerous photos. Can you recommend a stand that will allow a Nikon D80, so be positioned exactly.
Check with any decent photo shop for a tripod with a column which you can insert upside down. The Velbon Sherpa 200R tripod has such a column. They are available worldwide, or you can check their website for a picture of it, so it might be easier to describe to a sales associate. The common application is for nature photography, where you need to get the camera close to the ground. Have you thought about rotating the files in the computer?
Sep 09, 2009 | Nikon D80 Digital Camera with 18-135mm...
When i connect my d80 to my pc it freezes
You can try to a SD card adapter for the USB slot and download without the camera. The adapter is pretty cheap and sometimes comes with the SD Card.
The PC reads the camera as an external drive, make sure your PC and OS is up to date.
Aug 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
How do i set my nikon d70 to work on a vivatar flash
What Vivitar Flash? If an older model with only pc cord connection, you will need a Nikon AS-15 adapter. But you must also reaalize that if the firing voltage is more than 500volts, this may and possibly will screw up the camera if not the flash circuitry. Better off safe witha WEIN SAFE SYNCH HOT SHOE TO PC ADAPTER. Mounts to hot shoe on camera and allows pc connection cord to flash.
Dec 11, 2008 | Nikon Telephoto - Rear Lens Unit ONLY -...
Nikon D80 Exposure Count
My camera is now fixed. It was a tiny speck of dirt on the sensors between the mounting of the lense & the camera. The uy that fixed it said it is a problem with the camera because they are so sensitive.
Jan 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Vivitar V-2200GX Tripod Logo
793 people viewed this question
Top Vivitar Photography Experts
JP Services
JP Services
JOHN TOPLISS
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
