I have a 52" RCA DLP TV. Model # HD50LPW42YZX. I have a high pitched sound like a table saw running. The picture comes on with the sound. I just replaced the bulb and the color wheel. Now I cannot get the bulb to come on. Any ideas????
  • 18 more comments
  • bwelder Jan 09, 2009
    This is not a tube TV it is a DLP TV.
    This is the third bulb that I have changed over four years. I think it is installed correctly.
    The bulb is installed correctly. The actual sound is coming from the center of the TV.
    The sound is not coming from the TV speakers it is coming from the dead center, back of the TV. I do not use the TV sound system. I have a surrond sound system.
    Yes, The fans seem to be doing fine. This sound is loud enough to druve you out of the room. It sounds like a skill saw or table saw running!
    The sound is related to the light source. It comes on when the bulb turns on and goes off when the light is turned off. It is not speaker related.
    I reinstalled the old color wheel to be sure it was installed correctly. It is not rubbing anything.
    Now thatI know where the color wheel is located I do not think that it is the problem. The sound is coming from THE CENTER OF THE TV. Not the color wheel area.
    Does anyone have an answer to this problem?
    I checked the old bulb and my new bulb. I do not show any continuity between the two bulb connections. Should I?
    More info on the bulb continunity please!
    What is the dmd printed circuit board?
  • bwelder Jan 10, 2009
    I have double checked all of the connections and they seem to be right. The bulb still does not start up. Without a picture I do not have the screaching sound. I don't think the problem is actually with the bulb or the color wheel. Whatever was screaching is now finally broken ..... and this does not let the bulb and color wheel start up. Any ideas????
    The fans don't even start up.
    ...again, the fans do not start up.
    The cover is in place and the lamp door is closed. No start-up.
    the interlock is engaged.
    Yes, the green light on the front of the TV comes on.
    I will check the connections again. Did the light engine cause the "skill saw" sound?
    I just took out what must be the entire light engine including the bulb, lens etc .... in one piece. All cnnections look okay. I reinstalled the unit, connected the large white power supply cable, the small ballast connector, and the two large red wires to the side of the bulb. I installed the TV cover with two screws to hold down the interlock and started things up.
    The TV green light comes on but nothing else. ????? Would you like some spare parts cheep?
    Yes, I replaced the color wheel and the lamp. From what I see on the internet this particular RCA set is a piece of junk. I think I will go to Costco and get a new set. Do you have any recommendations on a 52" LCD? Are you near Northern California by any chance. You have been helpful. I will "accept" after your next response. Contact me at bwelder@raymndhandling.com if you would like some RCA parts.
    Thanks,
    Bill Welder
  • 19,396 Answers
Color wheel is not the only part making high pitched noise on the TV.
If the noise is from the color wheel, lamp may not start up, in that case your original lamp may still be good.
Give the tv to a local technician, with all the parts already purchased and available this may be an easy repair.
Posted on Jan 10, 2009
  • 2,071 Answers
The DLP TV (Digital Light Processing) technology, which Texas Instruments developed, to project images. These projectors contain a DLP board that contains a memory chip, a microprocessor, and a specialized optical semiconductor called a DMD (Digital Micromirror Device). The screen on a computer monitor is composed of thousands of pixels, or picture elements; each pixel has red, green, and blue subpixels that, when illuminated, form an image. Something similar occurs in a digital projector. The DMD is only about 1/2-inch wide and contains close to 1 million microscopic mirrors. Each mirror represents a pixel. As the DMD receives data that tells it how bright each pixel should be, it switches the angle of each mirror. The DMD switches its mirrors thousands of times per second, directing each mirror to display the appropriate color and brightness. This would create a monochrome (black and white) image if it weren't for a color filter. The color filter lies between the projector's bulb and the DLP board and directs the correct combination of red, green, and blue light toward the DMD's mirrors, adding color.
Hope it may help;
Regards;
VOTIT
  • 505 Answers
You can listen to solve your problem. Turn on the tv.. you will hear the hum of the fans.. then the colorwheel will spin up (high pitched, you hear it get faster and stabalize) and then the DMD board (engine board) will tell the lamp driver (ballast) to fire up the lamp. If the lamp does not light, you will get a 1 second buzz noise (this is the spark gap firing instead of the lamp). If you hear the spark gap, the lamp is where the problem is. If you don't hear the spark gap, but you hear the colorwheel, then you ballast is the problem. The DMD board controls all this and can be causing the issue, or one of the cables plugged into it may be loose or backward (colorwheel).. The only other cable is a big high power one from the power board to the ballast, this powers the ballast, and in turn the lamp. Tell me what you hear and we can solve together. These RCAs are known for getting defective lamps.. sometimes the connections can be loose causing problems, tighten very carefully! The lamp is very fragile and you can break the lamp or connector very easily. Let me know and we can solve.
  • thielectronick
    thielectronick Jan 10, 2009
    You said the fans were fine, now they aren't going. Something must be happening.. The lamp door needs to be closed or this TV will not turn on. If you don't get fans, check power to the tv, check power supply to start, then follow the listen-type troubleshooting. good luck
  • thielectronick
    If they did start, something happened since then, wire came loose, etc. double check
  • 108 Answers
Make sure the color wheel was installed correctly because if it was not and it is not spinning at the right rpms then the set will not not fire up. also make sure you have the connector on the dmd pcb connected.
Posted on Jan 09, 2009
  • 7 more comments
  • Chuck Jan 10, 2009
    it is thick cable that looks like a DVI cable on both ends. If it is not connected then the set will not fire. In fact, checkk all of your connection. They should be pretty straight forward. It has two little silver screws on both ends of it.
    also make sure the rear cabinet is installed and the lamp door. There is a interlock switch that must be engaged or the set will not fire.
    nothing will fire up at al if the rear cover is not on the tv or the lamp door is not installed. make sure they are in place. because of the safety interlock switches that they engage
    does the power light come on??
    something must be in the wrong with your connections then, it should fire if all is back together, interlock swithces and all. triple check yourself. I just changed an engine on one of those sets today.
    it is acually the bearing in the color wheel that does it. A new engine has the color wheel in it already.
    lol. That just doen't make sense? Did you replace the actual color wheel??
    I like samsung, they are great sets and very easy to repair. I am in Georgia but always wanted to make it to california
    thanks
    Sergeant:
    Champion:
  • 435 Answers
Check the continuity of the bulb ( can do with a multimeter or ohm meter). Also check for any blown fuses around it in the board.
  • Karthik P Jan 09, 2009
    Sound may be due to some loose contact.
    How long has this been happening?
    Any burning capacitors you see ?
  • 47 Answers
I would suggest checking your color wheel to make sure that nothing is contacting and making a friction created noise...
    Master:
  • 416 Answers
It could be a leakage problem that is getting into the audio amplifier and the sound is coming out from the speakers. Or, it could be the high voltage generator that was disturbed during the move that caused it to create an acoustical output when expanding and contracting during the high voltage generation cycles.
Does the sound go up and down with the volume control or does it remain constant. If it goes up and down, put your ear up to the speakers and verify the sound is coming from the speakers.
If you don't think the sound is coming from the speakers, turn the sound level control to zero and listen to the set and try to determine form whence the sound is coming. If from inside the set, near the back, then it may be the high voltage.
If it is coming from the speakers, here is one idea: If the set has external audio outputs you can use an external amp and speakers and with the tone control turn down the high frequencies to reduce the high pitch sound.
If it is internal, sometimes you can remove the back cover and find the source of the sound and by changing the mounting or even adding some isolation to the source, slow down the transmission of sound. Sometimes a part maybe has worked loose and tightening up the mounting hardware improves the sound.
Good Luck
  • 716 Answers
The Table Saw Sound Could Easily Be Sound interruption Try Turning Everything Off In The House And See If It Still Does It.
    Sergeant:
    Novelist:
  • 326 Answers
How to change the bulb in a   television
http://www.flickr.com/photos/fixyourdlpcom/ just click the link below.
    Sergeant:
  • 378 Answers
Its quite possible that you have not fitted the bulb properly.
  • 916 Answers
Tube televisions have a flyback transformer and that is usually where the high-pitch sound comes from.
  • machadojr_fe Jan 09, 2009
    I apologize i missed that the first time I read the question on DLP tv's the color wheel if not sitted properly can make a high pitched whining noise.
    It sounds like a bad filter capacitor in the power supply or in the audio
    amplifier. The audio capacitor would cause buzzing even when the tuner is muted.
    Top Expert:
  • Televison & ... Master
  • 77,499 Answers
There is a cooling fan motor for the bulb, have u checked to see if the noise may be caused by a motor problem like a noisy bearing?
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Loud whinning, high pitch noise coming from TV when turned on.
The color wheel is likely bad and needs to be replaced.
Check this link it is for a samsung TV but the same principals apply
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Oct 17, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Lg RU-52sz30 rear projection tv does not go on
I have an lg dlp projection tv Model # 52sx4d-ub.I replaced the bulb,everything correctly,but no picture. LG says I have to have a tech come out to reset? Can you help.
Jan 23, 2009 | LG RU-52SZ30 52" Rear Projection...
RCA DLP TV, When turning the TV on you can hear a high pitched
The problem is the color wheel. You most likely have to replace the engine to get one though.
Jan 08, 2009 | RCA HD52W58 52" TV
RCA 52 inch tv will not come on and has no sound
you need flyback 259296 you can get one at the following link and they provide free online tech support to help you install it. Heres the link.
http://servicemanuals.vstore.ca/
Jul 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
