Question about Dryers
Maytag gas dryer did not work properly
I have Maytag gas dryer seems not working right,the burning gas just stays on about 5-6 seconds then it shut off and will come back on about 1 minute later,I replace both thermos and pl coil valve kit but the problem is sill the same,PLEASE HELP thanks. Model LDG5914AAM.
    Sergeant:
  • 311 Answers
So from my understanding you replaced both gas valve coils???? yes,do you have an ohm meter.it dosen't happen often but they could be defective.next if your house venting or dryer was very!!!!!!!!,it would have tobe very blocked up.the heat would open the safty thermo and stop the burner from firing.as a appliance doctor i would take your dryers temputure .lol.. but realy..how hot dose it get.not hot,ok the then dose the voltage drop out at the valve when the coils go out??if it dose its in the other componets before the valve.but if voltage stays presant when coil stops its in the valve area.manufactures used to have connector coming to the valve from the top side[newer dryers they are saving money and left it out then connections would be at the coils]put you volt meter probes there at connector.thats how it works.i had a thought on how to check the flame switch.its the box on the side of the flame tube,black with two wires.after the burner lites[you got to be careful]pull one of those wires off[its hot 110 volts]thats a rare problem but i've had to replace a few over the years[so they do go bad]if after pulling off dryer then works open the door and the power stops to that wire.[also with the power off i might loosen that flame switch wire so comes off eazy when pulled.if any other questions please feel free to email God bless ,tom
Posted on Jan 09, 2009
Maytag gas dryer LDG7500AAL flame won't stay on longer than about 5 seconds.
The resistance is too weak in the hot surface ignitor to keep the gas valve open and requires replacement.
Dec 22, 2013 | Dryers
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
My Maytag Model MDG3500BWW gas dryer will ignite and burn properly for about 30 seconds, then the igniter will glow bright orange, then shut off without igniting the gas. It will continue this cycle of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][
Aug 07, 2011 | Maytag MDG3500BWQ Dryer
Maytag Neptune MGD9700A The heater was getting warm but not drying hot. I replaced the coils (servos) first. This did not solve the issue. Then I replaced the Thermistor, the thermostat and a second...
remove venting from back of dryer and run a test load with clothes if it dryes clothes with venting off then its a venting problem.....remove from back of dryer
Jan 31, 2011 | Dryers
I have a older Maytag gas dryer DG612. The igniter comes on the gas lights, runs for about 5 seconds then shuts off. The process repets its self over and over again. It is trying to start but shuts off the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 16, 2010 | Maytag MDG7600AW Gas Dryer
I have a Maytag Neptune gas dryer that is approx 8 yrs old and has worked great as far as drying time. The gas will now light and stay on for 15 seconds and then shut off, in 2 or 3 minutes it will light...
to me it sounds like your venting going out side,if it doesn;t get a clear flow it will come on and off the thermastate inside sencing to much heat.try unpluging the vent then try it if it stays on then you know your answer
Sep 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The heat in my gas dryer does not stay on. What
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Mar 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Initial gas burn does not reignite
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE;
Jul 26, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
103 people viewed this question
Top Dryers Experts
