Was working fine and then boom. power off. wont start again. no power
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
SOURCE: I have a Nordic Track exp1000 i fit and the track is not working.
It's either the electronics console overlay -- this thing often goes on this model -- or your motor is shot.
Have you ever seen it working?
Repairs can expensive.
You can buy an excellent replacement console electronics part for $100 (http://www.treadmilldoctor.com/Nordictrack-Console-Keypad-Overlay) , but if it's actually the motor, then you've still got more to spend.
In home service can easily run $150 for the call plus cost of parts.
If you decide that you're not going to try and get it repaired and you're going to toss it, I'd like to buy some plastic housing parts off that non-working unit from you. Please email me directly.
Cheers,
Mark
[email protected]
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
SOURCE: Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
