Question about Symphonic SC3813 13 in. TV/VCR Combo
Symphonic sc1304, vcr problem
Tapes will not play, ff, or rewind. Trying to ff or rewind causes tv to turn off and tape to eject. Trying to play a tape just causes snow with no sound, either. The tv works okay, otherwise.
  • 41 Answers
Pulley belt stretched, replace. Remove the back cover to tv, slide the chassis out, remove speaker connector, and other ones to allow the chassis to be out away from cabinet to take the metal cover off surrouding the vcr unit. Usually a couple of screws that hold the whole vcr unit in, remove these, lift the unit from the chassis carefully and check the belt as it is stretched and not making tight grip on the white pulleys that perform the mechanical functions of the VCR. When putting back together, and replaced the belt be sure to lift the vcr door inward before sliding the chassis back into cabinet so the door latch will open and close properly, otherwise you put a tape in and the door won't open back up.
Posted on Jul 22, 2007
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
Err on display when insert tape, no functions work.
Two things. First there is some damage to the tape transport mechanism. Only a good look around will confirm this. Secondly a faulty mode switch.
Jan 14, 2013 | GE VG4250 VHS VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Tape loop stays in vcr when ejecting. Tried a few tapes and am able to easly get tape out and rewind it. With cover off.
this sounds like a ff/rew idler worn or dirty or a worn slack belt will need to be cleaned manually or parts replaced
May 22, 2010 | Televison & Video
Tape ejects after playing for about 30 minutes
it could be dirty pinch rollers causing the tapes to tighten and be ejected. try fast forarding the tape to the end and rewinding. if this does not cure the problem, run a wet cleaner tape through.
Mar 05, 2010 | Emerson EWV403 VHS VCR
My EWC1394 records programs, but when I rewind th tape, it shuts off. This happens several times before it starts to rewind the tape.
this is caused by the tape winding too tightly so when it rewinds it gets tension and thinks it is at the end of tape ,so stops.
It pays to FF and REW several times on new or other peoples tapes to have the tape acclimatised to the tension on your machine. It may also need to be serviced if it is doing it to tapes you have previously FF to the end and rewound. Older tapes stretch a little more than new tapes so are more forgiving.
{Plese rate our help ++++Thanks for using FIXYA
Sep 26, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Tv vcr combo
The best way I can think of is to REMOVE the rubber band that loads the tape into the transport unit.Be KILLFULL (careful) the band is right next to the B+ (power supply) or the A\C 120volt
( and if u can find the replacement rubber bands, buy 2 kits)
Nov 16, 2007 | Symphonic SC319C 19 in. TV/VCR Combo
Eats tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
Symphonic SC3813 13 in. TV/VCR Combo Logo
161 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
