Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
My Frigidaire dishwasher won't turn on when I hit start.
Yes, it's plugged in and the outlet works. No buttons work.
SOURCE: Washing light flashes on Frigidaire FDB1050REM dishwasher
I'm not sure what combination of these steps fixed the problem but its fixed none the less.
As mentioned above i removed the screws at the top of the door removed the top cover. I disconnected the power connector (white) and reconnected. I removed the latch assembly cycled the latch a few times pushed the connectors on the bottom snuggly on. Reassembled the top and the replaced the screws.
After closing the door...all the lights were blinking?? No No its ok..
Place the dial on rinse only and press dry and start/cancel. This will place the dishwasher in a maintenance mode. It will cycle through all the cycles in a short amount of time.
After all of that it started up just fine. Like i said I'm not sure what part of this process made this all work I'm just putting it all out there and i hope it helps someone else with the same problem...
Posted on Mar 11, 2008
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Posted on Feb 11, 2009
  • 35 Answers
SOURCE: frigidaire dishwasher not working
you will need to replace your touchpad.
Posted on Jun 25, 2007
  • 130 Answers
SOURCE: Frigidaire Dishwasher Energy Star blinking lights.
check to make sure that the contrls are not locked.sounds crazy but i see it alot
Posted on Feb 16, 2009
  • 457 Answers
SOURCE: Bosch Integra 500 dishwasher turns on and starts
your controlboard is no good. find out if its a recall unit go to thermador.com which is the company that owns bosch and they can tell you the price if you have to oreder it or if its free for part and you pay labor to install
Posted on Mar 03, 2010
Frigidaire Dishwasher not working
try pressing button instead of hitting it, then check water inlet, check the filter at the inlet pipe if clear
Mar 18, 2013 | Dishwashers
Reset frigidaire dishwasher model FDB1100RHC
I had the same issue. I unplugged the dishwasher and plugged it back in. Bam! It's working fine now.
Oct 16, 2012 | Frigidaire Dishwashers
Start button won't work, but delay does
have you accidently turned on a safety feature stopping the machine from starting? or is the door latches closed fully, if opened slightly could be preventing the machine from starting. or maybe its just a faulty start button.
Jul 16, 2012 | Electrolux Frigidaire Professional Series...
The clean button blinks. the only button that works is the drain button.
Hello
Confirm that the door is closed and latched. dishwashers can detect if the door is open and will cancel any cleaning cycles to prevent water spillage. Wait for around 20 minutes before unplugging or moving the dishwasher in case the washer is cooling down, draining or drying dishes. Call a technician if the dryer does not restart.
Verify that a cycle has been selected using the "Cycles" button and that the "Start/Resume" button has been pressed. Unlike some models of dishwasher, appliances won't start until you select a cleaning cycle and press the "Start/Resume" button.
Confirm that the dishwasher's electrical outlet is switched on, if necessary, and that power is being supplied by plugging in a lamp. You may need to replace a fuse or reset a breaker on the electrical circuit if the lamp will not work in the outlet. Ensure that the dishwasher is plugged into the outlet.
Ensure that the water shutoff valves at the wall are open and that the supply hoses are free of kinks. Your washer will not start if it is unable to access the water supply. Most shutoff valves need to be turned clockwise or moved to the "Open" position to work properly.
Open the door and check the overfill float in the bottom of the dishwasher. Push it down to make sure it can move up and down freely. The machine will not start if the sensor is stuck at the top. The overfill float looks like a small cone on top of a disc with a paddle attached to the side.
Sep 12, 2011 | Whirlpool DU1055XTV 24 in Builtin...
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
We have Frigidaire 24 in. FDB1050REC dishwasher. The control panel has no power; no lights and nothing works. This problem started after a power outage. All circuit breakers in house ok and other outlets...
more than likely fuse is gone in plug. take dish washer out. change fuse in plug. if it doesnt work get extension lead and run it from a socket that definatly does work and plug washer into that. if nothing then its internal.
Jan 16, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
1,162 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
