Question about iiyama S 900MT1 (White) 19" CRT Monitor
Monitor takes time to display image
As soon as I start my pc and monitor, I immediately don't see the image in my monitor. I have to wait for around 10 mins before monitor starts displaying the screen but then it goes off immediately and this contiues for some 10 mins before the monitor stabilises itself, then I can start working normally. This is basically after only around 20 mins. I am not sure whether my monitor is nearing his death or I am missing something in this. Thanks Ravi
    Genius:
  • 1,056 Answers
If it is a CRT, I agree with Marty. Do you have access to another monitor? If so, trade it with the one that is having a problem just to make sure it is a monitor problem, and not a video card problem.
Posted on Oct 11, 2013
  • 883 Answers
Sounds like a slow CRT death to me.
Posted on Jun 05, 2007
SOURCE:
Monitor won't wake from sleep!!!!!!!
Sounds like you may have a bad connector. Make sure it fits snugly in the pc and the back of the monitor. If you still get no input try a different connector
I’m happy to help further over the phone at https://www.6ya.com/expert/tami_f8d2d553d5094045
Mar 31, 2017 | ViewSonic Computers & Internet
Monitor says it its going into power saver mode. Amber light stays lit on front of computer. I disconnected the cord from pc to monitor and then the display says no vga connected. Help!!!!!!
The power saving mode is engaged when no signal comes from the pc - the pc is either stopped (start it) or it's defective.
If you can't start the pc then you will have to dismantle it and test the components, starting with the video card. If you don't know how to do that then take it to a repair shop - don't make the problem bigger by messing around with it.
Jul 06, 2011 | Dell Inspiron 545 (884116037743) PC...
My monitor shows image immediately when switched on but just as soon the image appears the screen of the monitor goes dark after that need to off/on the power switch three to four times before the image...
Please restart your computer and tap the F8 key as soon as you see something on the screen. You should get the advanced boot menu. Select Safe Mode from the list.
Let me know if you were able to boot to safe mode.
Jun 18, 2010 | Dell E193FP 19" LCD Monitor
My comuter w0n't stay on
o.k. unfortunately this may mean your monitor is in need of a service repair technician. The same thing happened to my hanspree monitor. Lucky for me mine was still under warranty. How about yours? how old is it? If it is not over 2 years old you may still have a warranty on it. please also try this: --------------------------------------------------------------------------------------------- so, it automatically shuts down? try turning on your pc and do not wait for it to boot to windows. instead, immediately tap on F8 key several times as soon as you see that there is power. it should lead you to Windows advanced options menu, highlight disable automatic restart on system failure using your down arrow keys then press enter. it should start normally or if problem still persists, try safe mode instead. it would isolate the issue. if in safemode it will still shutdown automatically then you need to replace your harddrive. if not, then you should just reinstall your operating system to have your system work fine.
Apr 10, 2010 | Compaq Presario 5000 PC Desktop
My monitor suddenly lost signal and hasn't returned
do you mean the processor fan that is located near on the left top corner on the motherboard? if that stopped working then turn of your pc immediately. probably the cpu overheated. if that fan does not work replace it immediately as it will burn the cpu.
Jan 25, 2010 | eMachines T6534 PC Desktop
CRT Monitor Displays only a thin bright horizontal line
Vertical IC loose connection. Best is to reflux it or resolder. It is in internal circuitry inside the monitor commonly an upside single line IC.
And its a minor repair only. But I recommend it to be serviced by a qualified technician. Inside it are plenty of nasty voltages. It might caught you.
Apr 10, 2009 | Computers & Internet
Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
Westinghouse LVM-37W3SE PC Monitor
1. Genaraly 14" and 15" Monitors supported Up to 800by600 some monitors 1024by768pixels 17"monitors supports 1024by 768 to 1280by960 pixels and Other 19",21" are supported 1280by1024 pixels at the same time change the screen Refreshrate at display properties.
Oct 01, 2008 | Computers & Internet
Monitor displays slowly after the computer starts.
Sounds like an inverter issue. Can you see the image very faintly if you put your nose up to the screen?
Oct 07, 2007 | Samsung SyncMaster 540N 15" LCD Monitor
iiyama S 900MT1 (White) 19" CRT Monitor Logo
224 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Marvin
Marvin
RS Technology...
RS Technology...
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
