Question about Husqvarna Husky 165
Trouble removing face cover for oiling
The manual says to "Open face cover and oil the parts indicated". It doesn't show or describe how to remove it. When I release the back tabs, there is still something holding it on and preventing its removel. I don't want to force it. Any help greatly appreciated. willb
  • Anonymous Nov 27, 2007
    Can't find any screws
Remove the 2 round plastic plugs on the front. Use a needle to pry them out. They come off easily. there are two screws under each plug. Good luck...
Posted on Mar 11, 2008
SOURCE:
Usha janome magic stitch removal of right side cover
If it is computerized, take it for service.
If it is a mechanical machine (not computerized), it probably needs oil. Old oil turns to glue and seizes the moving parts.
Use either fresh good quality sewing machine oil or pick up some Tri-Flow Synthetic Lube. Open the top of the machine, the cover over the left side, and the bottom bobbin area. Gently wiggle the handwheel and apply 1-2 drops of oil every place metal rubs on metal--do NOT oil belts, synthetic parts, Cams. You can follow up with hot air from a handheld hairdryer into the internal mechanism.
Your mechanical machine needs regular oiling--on the hook/shuttle every 8 hours of use, all over (as described above) every 40 hours of use, or every 6 months if in storage.
Oct 16, 2016 | Janome Sewing Machines
I'm trying to oil my machine, but don't know how to get the face cover off??
Perhaps the Owner's Manual will help:
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/38515358.html?p=1
Be sure to use good quality sewing machine oil and white grease as explained in the manual.
P.S.--from the manual's instructions, it appears that you do not need to remove the face plate to oil your machine.
Sep 14, 2015 | Kenmore Sewing Machines
I inhereted a bernina ferreit in cabinet need instruction manual
I believe you probably have a Bernina Favorit. A Favorit is an early mechanical Bernina sewing machine and, to Bernina vintage lovers, is a keeper. Favorits are the flat-bed version, not the free-arm version, but is a wonderful machine nonetheless. If you search the internet using:
Brand +
Model +
the word "Manual"
(ie Bernina 640 Manual)
you might have some luck finding a manual.
Or, you can join the Yahoo BerninaThirtySomethings group
Yahoo Groups, where older manuals are available in the Files section. In addition, you will have access to a wonderful resource of Bernina users/lovers including conversations on using, maintaining, repairing, and assorted other advice about your older Bernina.
The first thing you should probably do is pick up a good quality sewing machine oil (Bernina oil for CB Hook is recommended--however, never use 3-in-1, WD-40, cooking oil, or the old oil can that you might find in the machine's accessory box). Consult the owner's manual in the Maintenance section to clean and oil your machine. If the machine has not been used in several years, the motor may sound like it is straining to move the mechanical parts. Most likely, the old oil has dried out and is sticking things together. Do not force the motor to move things without first cleaning and oiling the machine.
Remove the top cover and swing open the cover on the left side where the lightbulb is located. Gently hand rotate the handwheel and while watching the moving metal parts, apply ONLY one-two drops of oil every place that metal rubs against metal. (Sometimes the oil ports are marked with red paint as a guide, but some machines are not marked.) Use only 1-2 drops at a time. Do NOT over-oil as too much oil can be as damaging as no oil. Gently move all the levers and dials and oil those moving parts as well. Do NOT oil the white plastic gears, the belt, or the large round metal cams (which your machine may or may not have). Then, tilt your machine back and remove the bobbin & bobbincase and with a soft brush, remove any lint, dust. Then while hand-rotating the handwheel and moving the levers and knobs, apply oil to the moving parts under the machine. The feed dogs are usually a problem so be sure to test the feed dog knob. If anything seems to be sticky, resistant to movement, you can also direct hot air from a handheld hairdryer into the interior mechanism to help loosen things. Be sure to place a drop of oil on the bobbin hook in the bobbin area (the manual should show this).
If there is anything that is still sticky, then a few more drops of oil and the handheld hairdryer should be employed until things are moving well again.
A Bernina is a great machine for the sewing enthusiast, but only if it is maintained and cared for regularly. Cleaning and oiling should be performed approximately every 8-12 hours of constant sewing, or every time a bobbin is emptied, or at least every six months if not in frequent use.
Aug 30, 2015 | Bernina Sewing Machines
How to oil a serger
Mostly I tell people to check their owner's manual, but I checked and yours is an older model serger which, like mine, doesn't have instructions for oiling. So, I'll just tell you how I've done it (mine is even older than yours, and gets hard use as I sew a lot).
1, On the flat plate behind the cutter, there are several holes with orange rims. A drop or two of oil in each. Then oil the hinge on the arm that holds the blade, I manually cycle the machine as I do this to get the oil to spread evenly.
2. Open up the looper cover and remove the cylinder cover, manually cycle the machine to see the parts move, then oil anything that moves as you manually cycle it some more to get the oil into the moving parts. I tend to use a good bit of oil on the lower parts as they get pretty dirty, then let it sit for a while (I often do it as I'm finished for the day), and sew on a scrap when I start again to be sure there is no oil in the thread that would transfer onto the garment.
Mine usually gets a good cleaning and oiling every 10 or so hours of sewing and it has lasted *really* well.
Aug 23, 2014 | Singer Sewing Machines
Stop motion wheel frozen. undid screw but not able to unscrew or loosen wheel. Machine runs beautiful except for this one issue.. how can I get this motion wheel off or loosened so that I can wind bo
As a simple fix you can buy a freestanding bobbin winding device online, this will wind a bobbin for most machines so is a simple fix and can be used at any time.
You may also want to remove the top cover of your machine and oil internally, it may help with the fly wheel issue. There is an oiling diagram for a White 1510 on this page http://www.sewusa.com/Sewing_Machine_Repair/White_Sewing_Machine_Maintenance/White_1505_1510.htm
If your machine top cover looks similar and you can remove it then certainly use this image as a guide to oil in the arrowed places, then manually turn the flywheel towards you gently to spread the oil. Use a good quality clear machine oil, or Triflow if you can, it has silicone in and doesn't dry out and leave sticky residue like a mineral oil can over time.
From reading the manual for the White 1418 on the Singer website, it looks like you hold the outer part of the flywheel and turn the inner knob towards you to disengage the clutch for bobbin winding. Is that what you have described above?
If you don't have the manual you can download it from the Singer Instruction manuals page, link is http://www.singerco.com/accessories/instruction-manuals, then type W1418 into the search field and click "search" then wait for the screen to load, you'll get a "Free download" icon on the right after a few seconds. Click this and wait again for the pdf file to download, it will take a bit of time depending on your internet speed.
Nov 14, 2011 | White Sewing 1418 Mechanical Sewing...
The hand wheel is very stiff and the foot control cannot electrically move the needle up and down either...just humms. The machine looks like it has had very little use. From the 70's and I just...
The top cover just pops open which is why there are no screws. Just push up from the front side and it should open. On older machines, this may take a little bit of force. :)
Aug 26, 2011 | Kenmore Sewing Machines
Where do you oil this machine -- it's not in the owner's manual.
Welcome to FixYa! on the list below is the steps to oil your sewing machine.
  1. Remove the screw from the top of the Janome face plate with a small flathead screwdriver. The face plate is on the top of the sewing machine directly above the needle.
  2. Pull the face plate up and away from the sewing machine gently.
  3. Face the sewing machine as if you were about to start sewing.
  4. Locate a small cylinder attached to the side of the sewing machine facing you that had been covered by the face plate. Apply one or two drops of oil to the top of this cylinder.
  5. Locate a small square that is directly above the needle of the machine, also previous hidden by the face plate. Apply one or two drops of oil directly above and below this square.
  6. Replace the face plate and tighten the screw.
  7. Open the hook cover of the sewing machine as if you were changing the bobbin. This area is located directly under the needle.
  8. Remove the bobbin case by grasping the lever on the case and gently pulling the case out from the machine.
  9. Remove the hook ring and the hook. These two parts are behind the bobbin case and should come out easily.
  10. Apply one drop of oil to the center of the hole the bobbin was removed from.
  11. Replace all of the parts you removed from the sewing machine.
Good luck
Nov 09, 2010 | Janome 4052LX Mechanical Sewing Machine
Kenmore 158.17921 Need to know where to oil? machine sticks at times. Do not have a owners manual.
Remove the two large screws that hold the top lid on and remove the lid. Open the left side cover where the needle bar and presser bar are. Place one drop of oil on everything that moves. Oil moving parts on the bottom. Blow off excess oil with an air compressor.
Sep 30, 2009 | Sewing Machines
I can`t get the face cover off to oil it
on some of the kenmores there are 2 screws under the carring handle on the top of the machine you have to remove these. then lay the machine back and remove the screws on the bottom.the case should come of. if not there might be screws on the inside of the bottom plate.
Mar 09, 2009 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
176 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
MissFixIt828
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
