Question about Kenmore 22422 Top Load Washer
Series 70 Kenmore will not spin on any cycle.
It sounds like the transmission is engaging, as the dial cycles. How do I look for an obstruction under the agitator?
Since the washer would still pump out the water, I removed the cover, then the pump, then the motor and I then found the coupler was broken.
Posted on Jan 10, 2009
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 series
sounds like the lid switch has failed-no clicking usually means it is broken.
If you can get the top control panel up,you will see the molex plug that connects the harness to the switch.Jump the white and gray wires out and see if the unit spins.
Good Luck!
Mar 22, 2009 | Kenmore 20722
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Kenmore series 70 washer
On kenmore, which is made by whirlpool, there is a couple of coils attached to a bracket this is called a wig-wag.
they are located underneath the tub. when these coils engage they move a couple of bars, thus selecting agitate, spin, ect. It sounds like one of the coils is not working. Check them for power and continuity, and then go from there.
Nov 05, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
100 people viewed this question
Sal De
 Brian Main
Brian Main
