Question about Sony Ericsson P990
Sony kv29f3u Hi I have sound but no picture, turned tv on this morning to a problem can you help? Please
0 characters
1 Points
When i touch the sony ereader to advance to the nex page, it goes back one page...also there is an L on the left side on my screen. I will appreciate some help with this. thank you
Hi sarina5,
Sounds like the "Page Gesture" feature on the reader is on the opposite way, check out these steps:
1. Press "Home" button
2. Tap on "Settings" or "More" then tap "Settings"
3. Tap on "Page Turn Gesture" to change the direction to turn pages when using th touch screen.
Hope this info helps you!
Jun 26, 2011 | Sony Reader Touch PRS-600
Hi, my sony e-reader while turned off or on appears to have what looks like white horizontal lines across the top of the screen which prevents me from viewing any text at the top of the screen.
Without seeing it exactly, it sounds like it could be one of two issues:
  1. You should try charging and resetting your ereader. Please be sure to save everything, as your system will go back to its original default settings.
  2. If option 1 does not work, it sounds like you may have damaged the internal "ink" - this typically happens by dropping the ereader. If this is the case, unfortunately the damage is permanent by can be fixed by a professional or via Sony.
Feb 09, 2011 | Sony Reader Touch PRS-600
Hi, My touch screen has gone dead. Is there any
Since the screen is dead I would suggest the easiest way to back up / access important content is through your PC/laptop. Install the necessary Sony Ericsson software on your computer and and connect it to your Sony Ericsson P1i and follow the back up instruction. Hope this helps. Please rate
Dec 30, 2010 | Sony Ericsson P1i
Hi i cant get picture messaging or send them please help thank you
it depends on what provider you have. ive heard that for sprint, if you have a data plan, you can get pic. mail. On the sending it, your sms is actually an email. if you text your email, it will give you your sms email address. you just have to send the picture text to the persons sms email
Mar 26, 2009 | Sony Ericsson W880i Walkman Smartphone
ATT Tilt - No Display at all
they have the replacement screens for this phone
Aug 05, 2008 | AT&T 8925 Tilt Smartphone
Display doesn't work
LCD Ribbon Connector may have become dislodged or in partially disconnected somehow. You have to open up the case and reconnect the lcd.
Jul 03, 2008 | HP Jornada 720 Pocket PC
Mp3s have no sound?
Please buy a apple MP3 Player which would help u
May 24, 2008 | Pantech Duo Smartphone
It wont turn on
you can just try to reformat your memory card. Also check for possible virus infection on it. Good luck.
If you may have additional questions pls feel free to ask Fixya.
Mar 29, 2008 | Nokia N82 Handheld
Sony ericsson k810i no sound
Have you tried to turn on the call volume? On the right side of the phone you will see two buttons, up and down.
Try making a call. Then, while on the call and before you hang-up, press the button on the right side of your phone, the one with the arrow pointing up. You will see a volume indicator on the screen. If you press the up button again and again the volume will go up until it reaches a satisfactory level.. Perhaps your volume is set to very low.
Hope this helps...
Feb 24, 2008 | Sony Ericsson K810i Blue Smartphone
Hi, did you try taking out the battery and letting it discharge overnight then pop the battery back in, plug the pda into the power mains and try to turn it on again?
Nov 28, 2007 | HP iPAQ hw6515 Pocket PC
PDAs Logo
Top Sony Ericsson PDAs Experts
David Payne
David Payne
Are you a Sony Ericsson PDA Expert? Answer questions, earn points and help others
