Question about Samsung Televison & Video
Swicthed on tv and its a blank screen..now it wont switch off.
Everything seems to be working fine up until this morning...i had a samsung dealer set up the tv 4 months ago...this morning i turned it on and nothing came up on the screen..it was blank..the little red light on the side flashed everytime i touched a button but nothing happend...i checked all connections and even tried turning it on from the set but the screen just looks like its off...but the source button wont go back to stand by,its like its still on...PS..i cant find my model on your site..its a LA46A65OA1FXXY 46inch LCD.
  • lizblacky Jan 09, 2009
    Thank you for your swift response. I unplugged it and then plugged it back in and it was fine after that. Was wondering if I need to get a new power board incase it surged??
  • lizblacky Jan 10, 2009
  • 362 Answers
Can you see the menus on the screen?
Can you hear audio (sound)?
If you can hear sound but no menu we need to check the backlight.
Take a flashlight and shine it on the screen, look very closely at the screen.
Do you see a video image?
Let me know what happens, I can assist further.
lone99star
Posted on Jan 09, 2009
  • Rob Kent
    Rob Kent Feb 24, 2014
    How about a Samsung Plasma with same symtoms. Power board seems fine , replaced all Caps, have all proper Voltages. Green Led on logic board fklashing correctly ( not slowly)
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My xbox360 wont play movies my ps3 blank screen
you need to configure both to hdmi or not to hdmi in order to get any picture out whatsoever on the xbox its a switch on the video and for ps3 it needs to be done in the settings but they both need to be done before changing tvs otherwise
Robb
Apr 28, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung LCD tv - Turns on and off by itself.
Since you have another TV with the same problem you can try using an antenna(indoor model ok) to see if the cable is causing the problem. If not return TV before the warranty expires.
Mar 03, 2009 | Samsung LN46A850 LCD TV
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
New Samsung TV and home theatre kit
on the receiver thier is a swicth it is iether set to amp or tv/amp, amp will set it so you have suround sound, but you'll not have sound out of tv and you'll want it that way. the other with tv/amp will give you both. hope this helps
Sep 06, 2008 | Audio Players & Recorders
Televison & Video Logo
298 people viewed this question
Henry  Thomas
Henry Thomas
