Question about Kitchen Ranges
Oven not work
Hello
I have a whirlpool range which does not want to heat up.The model #is WUP39800. When you push the bake botton it comes onwith the oven temperture reading 70,and holding, after some time we get an error code FE2 with a picture of a look in front of it. Can it be fixed?
Thanks,
Domenic
  • Domenic Iannone Jan 18, 2009
    Hello dmparenti
    Thank you very much for going above a beyond with the repair of my range. I had to wait for the temperature sensor come in. I picked up on Sat. the 17th and installed it. It works like new. Thanks again for your expertise. I defiantly rate you a five star
    service technician for diagnosing my problem.Keep up the good
    work. Thank -You !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Sincerely,
    Domenic (peppinno)
    iannone@sympatico.ca
    Scholar:
  • 58 Answers
It can be fixed, that falt means your oven got to hot. Recomend replacing the temp sensor.
dmparenti
Posted on Jan 10, 2009
Whirlpool Standard Cleaning Electric Rang Model RF315PXKQ
hi,
Can you please tell me if you have replaced the thermostat?If not then please do that.
Waiting for your reply.
Feb 24, 2008 | Whirlpool RF369LXPQ Electric Kitchen Range
Part number for lower heating element on RF365
Hello there:
Here is the info and a pict for you this is from repair clinic.com all you have to do is enter the model number you supplied to me and the parts list is listed for this oven
Item #
1028468 Price
$50.15 In Stock?
Yes Oven bake element assembly with push-on terminals
Recommended related tool(s): 1164336
Oct 05, 2010 | Whirlpool RF365 Electric Kitchen Range
My gas oven, Super Capacity 465 the oven nor broiler light. The stove top works fine.
Hello there
Please read the entire solution i have provided below ok
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician.
Sep 28, 2010 | Whirlpool GS460 Gas Kitchen Range
Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | Frigidaire FEF355 Electric Kitchen Range
My whirlpool oven will not heat up or bake or
Should still be under warranty! Call the dealer. Make sure you have the model # and serial # from the tag on the oven first. It is the ONLY way they can check warranty status. If not covered, it is probably the selector switch
Mar 31, 2010 | Whirlpool GS445LELS Gas Kitchen Range
Gas oven will not work
No, the broiler does not work either.
Jan 26, 2008 | Kitchen Ranges
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Uneven heating in our Whirlpool range
on bake setting only your bake element is on broil element comes on for preheat only naturally the top part of your oven is hotter heat rises take the temp in the center of oven with a good thermometer
those cheap ones are a guide only dont swear by them
Dec 06, 2007 | Kitchen Ranges
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Kitchen Ranges Logo
112 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
