Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
I have a Sony Grand Wega 61" that is only 2 years old and the screen goes black for a couple of minutes and comes back on. It's not losing sound, just the picture. It was only happening about once an hour and has gotten worse over the past week. Could this be the bulb
  • 2 more comments
  • lisacraig Jan 12, 2009
    The fan is fine. I am calling a repair center today to come look at it. After reading other posts on the internet, it's probably the lamp driver. We definitely will not buy another Sony. We didn't purchase the extended warranty, thinking that being a Sony, we wouldn't need it. The RCA 36" we purchased 10 years ago is still going strong with the new owners we gave it to. We put our RCA 37" LCD flat panel wide screen in the family room and noticed it actually has a much better picture than the Sony 61" does. The next one will be a Samsung Plasma and we will definitely buy an extended warranty.
  • lisacraig Jan 13, 2009
    Thanks so much for the info on the Plasma. We do still have one older set (15 years old) outside on our patio that is going strong too.
    I spoke with the repair shop yesterday and he said he "thinks" it's the bulb going bad and if they came out and charged me $365 that's what they would replace. Being that we can get the bulb for $200 and my husband can do it himself, we'll just try that.
  • lisacraig Jan 21, 2009
    I ordered a lamp online for $180 including shipping. My husband worked late, so I decided to play TV repair chic!! It took all of 5 minutes to replace and the TV works beautifully. So I saved $185 by doing it myself. Just because there isn't a code doesn't mean it's not the lamp!!!
    Thanks for the comment. It made me quite proud and my husband was too, although he would never tell anyone that I'm the one that fixed it!!! lol ;-)
  • Sony Master
  • 5,568 Answers
It could be but it may be cycling due to heat; if you turn the sound completely down and listen at the rear of the set, you should hear the murmur of a fan. I would listen when video is there and when it isn't to sense if there is any difference in low-level noise coming from within.
If you don't hear a fan, it may be either burdened with a dust buildup or failed. Any set that uses high-temperature light sources will be protected against fire or internal damage by a thermostat of some nature that will trip and reset by itself.
Posted on Jan 09, 2009
  • Steve Allison
    Steve Allison Jan 12, 2009
    It seems that the quality one could expect from Sony is history judging from the number of problems folks are having.
    I would urge you to do more research before buying a plasma set. They are on their way out since the advent of ever-larger LCD screens.
    The margin the plasma sets once had over LCDs in brightness, viewing angle and color saturation has nearly disappeared so the plasmas no longer are that much more pretty to look at.
    The plasmas suffer from a disease similar to CRT sets in that they use a phosphorescent coatings to generate light and this construction is subject to burn-in in the same manner.
    Since all of our consumer stuff seems to have much less life in them than we were accustomed to, maybe the screen construction isn't important; everything seems to be dying in 2-4 years anyhow.
    Because of the huge number of failures of all later TVs, I've been advising friends and family to get a converter box and put it, and their old sets, in a nice dry place so they have a backup when their formerly 'gorgeous' big screens bite the dust.
  • Steve Allison
    Steve Allison Jan 21, 2009
    I guess congratulations are in order!
    (Darned women taken' over everything!) ;-)
Sony 60" Grand Wega has Picture go BLACK and NO SOUNDS!!!
My Sony Wega KDF-55XS955 55" was going on for 1-2 minutes then going black with no sound and after a few minutes would come back on. After reading all the posts and talking with a repair guy I replaced the bulb and that fixed the problem.
Aug 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
My Sony 54" Grand Wega rear projection TV is 4 years old in Sep. It has started losing picture and sound for a few seconds then comes back on. It is getting more and more frequent. . . like six times in 5...
A spent bulb will cause the whole set to go off. If you have not changed the bulb in all of these years, first you are lucky, and second that is probably the cause of your problem.
Aug 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No video but there is audio after replacing bulb
NAKE SURE YOUR FRONT COVER THAT GOES OVER THE LIGHT IS'NT ON TO TIGHT ALSO CHECK THE 2 SCREWS THAT MOUNT THE LAMP COVER MAKE SURE THERE NOT TO TIGHT AND THAT THERE BOTH SCREWED IN THE SAME AMOUNT AND ALSO CHECK THE FAN ON THE BACK OF YOUR T.V. AND CLEAN IT IF NEEDED
Mar 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Pictures goes black while power light blinks green
I have a 40 but i was having the same problem. It turned out to be my lamp. I got a brand new lamp from Projector Lamp Services (relampit.com) and my tv works fine now. Im pretty sure that the 40 and the 60 take the same lamp. You might want to give them a call.
Jan 05, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony wega 61 inch (odessa, tx)
TV is a Sony WEGA 61" model # KDF-E60A20
May 28, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Wega Rear Projection TV, Red light flasing
I had the same problem, it because of heat buildup, and the inside is fried, you need repair
Jan 02, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
