Question about Dacor Integrated Ventilation System - IVS1 Kitchen Hood
Part number for Davor IVS1
I am trying to find the bulb number for the 75W halogen bulb for my Dacor IVS1 hood. Any help would be greatly appreciated.
Thanks,
Joe
Remove the metal filter screen. Reach behind (above) the bulb and rotate/unscrew the bulb by the base and it will drop out. Place the new bulb through the hole while reaching behind to screw it in the same way you removed it. Many replacements available online for under $6 plus shipping. Search in Google for "JDR E27 75W" (My dealer had said the bulbs would cost $40!)
Posted on Jan 07, 2012
  • 126 Answers
92348 is the part number for that lamp.
Posted on Jan 09, 2009
My Sirius Range Hood has two lights that take G4 Halogen bulbs. Is there a 115V bulb made for this application or is there something that converts the voltage to 12V?
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb is just as bright but runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Nov 29, 2016 | Sirius Kitchen Ranges
Need replacement halogen lights for SU3
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Mar 07, 2013 | Sirius Hoods SU3
How do I change the light bulb on our dacor grill
You simply need to remove to cover, to access the halogen bulb. Use caution when removing and replacing the bulb.
Apr 26, 2011 | Dacor Epicure EOG303 Grill
How do i change my lightbulb in my dacor hood?
the lamp is 75w and it connect behind a circle holder that you can pool down gently with flat screw driver
Jan 13, 2010 | Dacor IVS1 Integrated Ventilation with...
The halogen light in a Dacor Range hood won't budge. Any suggestions how to get it out? Suction cup won't turn it.
Using your finger nail or a small flat-head screwdriver, gently depress lens retainer tabs. good luck
Dec 31, 2009 | Dacor EHD3618SS Kitchen Hood
How do i replace the halogen light bulb?
turn it off and light usually just pull off and if has lens most of the time they unsnap.
Jul 04, 2009 | Dacor IVSR1 Integrated Ventilation with...
Dacor oven light bulb
Yeah, it's a rip-off isn't it? Been there. :-( Find the bulb part number or electrical values and search eBay. I think this is what you're looking for:
G4 halogen 12v 10w, dacor part 86364.
A search right now shows multiple vendors offering 10-piece packs for $7.00 including shipping. I'm about to order a set myself.
Apr 17, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Problems changing a light bulb :)
You need the suction bulb that came with the unit.  In case you do not have it, it is part #62408 and is about $2.00.  I am trying to figure out for myself how to get the lens cover off in order to access the bulb, and how to replace it when the new bulb is put in.
Mar 26, 2008 | Dacor Integrated Ventilation System - IVS1...
Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
Dec 30, 2007 | Kitchen Ranges
Kitchen Ranges Logo
162 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
