Question about GE JVM1860 Microwave Oven
HOW DO I ROAST A CHICKEN IN A AC925CHS
CHICKEN
    Genius:
  • 1,605 Answers
Search the internet for “roast chicken recipe for microwave”
Here is one just in case you don’t find one:
Microwave Roast Chicken
3 lbs. chicken
1 tsp. salt
4 tbsp. butter or margarine
1 tsp. paprika
Instructions
Melt butter in a custard cup in microwave. Mix paprika into melted butter. Wash chicken (reserve giblets, these are best cooked conventionally). Sprinkle inside of chicken with salt. Cover ends of legs, tail, and wings with small pieces of saran wrap or wax paper. Place trivet on inverted saucer or small casserole lid in 12 x 7 inch baking dish. Place chicken breast side down on saucers. Brush with butter. Cover with waxed paper. Cook 12 minutes. Remove wax paper or saran warp from legs, tail, and wings. Turn chicken breast side up and brush with butter. Cover with wax paper and cook 12 minutes more or until meat thermometer registers 180 degrees (temperature will increase to 195 degrees during standing).
DO NOT USE MEAT THERMOMETER IN OVEN WHEN COOKING!! Remove chicken from oven; cover with aluminum foil and let stand 15 to 20 minutes before carving. Note: For other weights of chicken, allow 8 minutes cooking time per pound.
Posted on Jan 09, 2009
How do I DEFROST CHICKEN TENDERS ?
Here's How It Works:
  1. Run hot tap water into a bowl.
  2. Check the temp with a thermometer. You're looking for 140 degrees.
  3. Submerge the frozen chicken.
  4. Stir the water every once in a while (this keeps pockets of cold water from forming).
  5. It should be thawed in 30 minutes or less.
How to thaw a frozen chicken the fast and easy way
How do DEFROST CHICKEN TENDERS Google Search
Oct 31, 2017 | Microwave Ovens
My new westinghouse oven just took 3 hrs to cook a 1.8kg chichen and the roast potatoes now browned at all.
The problem may be that you are trying to cook a whole chicken in a microwave oven.
Aug 28, 2017 | Westinghouse Microwave Ovens
KENMORE ELITE #86013 Microwave/Convection Oven:Manual says always use Metal Rack when convection cooking.How can you cook whole chicken or roast? If you put food on top of the rack it will rub against
Yeah, that's an interesting dilema. You need to lift the food off the tray to get proper air circulation, but I've seen those racks and I understand that you don't have enough room to put a full bird in there! Is that by design, or an oversight? I don't know! And what can you do about that? Maybe you can cut off an inch off the support legs of the metal rack....
Oct 20, 2014 | Microwave Ovens
Can i use aluminium foil in convection mode in microwave
It is best to not use aluminum foil in a Microwave since microwaves cant go through it, so It will not heat properly. If you are using it only on Convection It is just fine, it is like using a regular over then. Same kind of issue though if you are using convection, that is to bathe the meat evenly in circulated air. If you cover it in aluminum you lose a little effectiveness of the convection on the food your cooking. If it is to stop splatter just make a small tent over it and maybe tooth pick it down. Letting the air flow get under it but not splatter the entire inside.
Aug 24, 2017 | Microwave Ovens
How do i deforst chicken breast
Put in ziplock bag. Submerge in cold water for about 1hour.
Dec 03, 2012 | Microwave Ovens
Need to know how to roast a whole chicken
Cooking meat is not a good idea especially chicken, few microwaves have a higher enough temperature to properly cook it, you are using a 700 watt microwave, the core temperature is simply not high enough to properly cook the meat. I strongly recommend the regular oven for proper cooking and safety, plus it will taste better.
Mar 28, 2012 | Haier 0.7CF 700W Microwave 700 Watts...
My delonghi ac925chs combination oven and grill work... microwave has stopped heating have noticed there is no light on in the microwave.and when i went to use it yesterday it would not heat in the...
Check this video it goes through checking and replacing magnetron, capacitor, diode and fuse. It will be one of those. Check the safety instructions in the description.
Sep 04, 2011 | DeLonghi Microwave Ovens
My de longhi ac925chs has suddenly stopped heating or defrosting but making all the right noises. The oven and grill still work ok. Is this just the fuse and if so, can i change it myself?
It's most likely a burned magnetron, and it's usually as expencive to replace than a new oven but since yours is equiped with a grill and conventional oven check the prices it could be worth changing...
Aug 03, 2011 | DeLonghi MW 535 Microwave Oven
I want to get an DeLonghi Microwave AC925CHS instruction manual
how do I change the time in my Lumina microwave oven?
Jun 09, 2011 | DeLonghi Microwave Ovens
GE JVM1860 Microwave Oven Logo
505 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
