Question about Food Processors
Operating switch This is an old model. The operating switch/dial on top of the machine has become very stiff. We have disassembled and reassembled the machine as far as possible but have been unable to release the stiffness.
  • jules_crickm Jan 13, 2009
    Thanks. Sounds possible. Will try and let you know.
You could try a shot of contact cleaner inside the guts of the switch. Perhaps over time some sticky residue has built up causing the switch to become frozen. Unplug the unit, spray inside the guts of the switch, work the switch back and forth. repeat unit the switch loosens up. BE SURE to use a contact cleaner that won"t damage plastics, will say on label!
Posted on Jan 13, 2009
Food Processor's light turns on but blades do not turn. Worked for about 5 minutes than stopped. It started to work again for about 10 seconds running sluggishly and sputtering, then stopped.
There will be a switch activated by correct engagement of the bowl, lid and pusher. Locate and activate that switch without the bowl on and see how it runs then. If it does then you need to figure out which of the bowl parts is not operating the switch properly. If activating that switch changes nothing then then you will need to be looking inside the motor housing, so far it's a place I haven't been on that model.
Jan 15, 2016 | KitchenAid KFP1333ACS Food Processor,...
Won't start;
A possibility that the micro switch inside which is actuated when you put the top on......the one you are tooth picking....has become dislodged, or the grooves that the switch hold it in place have broken off. Is there anything rattling inside the mixer which would suggest that a piece of the casing has broken off. If you can disassemble it to this point where you can see the switch and there is damage around that area which makes the switch loose, you could use some hot glue to hold it firmly in place. Let the hot glue set solid before you use it.....especially as the switch completes an electrical circuit and hot glue in its liquid form s conductive! Always remember to remove the electrical connection before opening the unit. Failing this, it could possibly be that the switch needs replacing which is a far easier job. Switches are pretty comparable regardless of what brand mixer. Sometimes held in with a screw on opposing corners. So even eBay would probably have one. Good luck. On the bright side, your solution works, but on the dark side, using a plug socket to switch a unit off and on is tricky! Saranden.
Nov 24, 2013 | Cuisinart DFP-14BC Custom Food Processor
Sunbeam multiprocessor model lc6200 runs full speed all the time
As other contributes have said, remove all the screws from the base, the spindle can be released by caerfuly prising out the small plastic clip halfway up the spindle, it will slide easily off and the large spindle drive wheel can be removed. Push the control knob out from behind, the knob and e surround come out as one unit. Remove the accessories holder and remove the two screws holding the top cover on. Now turn the unit the right wat up to start to release the top. Carefully prise the top cover off, there are two plastic clips at the front. Now you have exposed the top of the unit and the safety switch actuator. Remove the screws, the hardest job is to release the actuator rocker arm. I could not release the pivot support, so took the rocker off the pivot. Now you should be able to lift the cover off the motor and Access the control board. There are two screw holding the control assembly in place and two which hold the circuit board to the switch. Replace the Triac and diac then reassemble.
May 21, 2012 | Food Processors
No instructions on how to start my braun multipractic plus blende
There is a clear L shaped tab that is "in the lid" that you slides or rather you rotates into and threw a crevice slot that alows the top switch to turn on or "even move" for that matter. This seems to be a rather clever safety switch that is down right frustrating when your excited about using this machine, while thinking that we just switch it on like our lights...Safe machine...."will not work" period without the lid and bowl softly connected to the right arrow or line up markers.
Apr 17, 2010 | Braun K 600 CombiMax Food Processor
Some coffe got down in the base of my magic bullet. What do I do?
For a Step-by-Step instructional PDF on how to disassemble, clean and reassemble your Magic Bullet send an email request to: Tinker@TinkersWorkshop.com.
Jan 01, 2010 | As Seen On TV Magic Bullet Food Processor
Braun multipractic food processor model 4259.. Need the insert carrier. Spindle post from bottom to flange is 1 3/4 inches. Where might I find one? What kind of plastic is it made from? Would an epoxy or...
The disc carrier you're looking for is Part No 7002058 (the number may be stamped somewhere on the holder itself). It's like a circular/figure 8 kinda looking thing on a shaft. If you're in Australia I'll be able to help get spares.
Don't recommend using glue to repair due to stress breaking it again, and for food safety issues.
Mar 30, 2009 | Food Processors
Safety-rod of bowl does not depress microswitch of Cuisinart processor
Cuisinart does not have the original pieces available, but you can order a replacement work bowl, lid, sleeve, etc that will work from the company. First do a motor test to make sure the motor is still working:
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Oct 20, 2008 | Cuisinart DLC-5 Food Processor
Power red llight is on, but the motor/blades won't go
Well, now I feel totally foolish. The handle on the bowl must be toward the front of the bowl, not the rear otherwise the operating post won't engage.
Aug 22, 2006 | Cuisinart DLC-8S Pro Custom Food Processor
Food Processors Logo
291 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
