Question about Bulova Watch
Nelsonic watch with no instructions
Needs correct time set, also date.
  • Anonymous Mar 25, 2014
    program watch for correct time
  • 43 Answers
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Posted on Jan 14, 2009
Nelsonic digital wristwatch came without instruction booklet. How do I set time.
Posted on Nov 24, 2009
Nelsonic (NEL621 & NEL15AES & NEL611) 4 button Digital Alarm Stopwatch
Instruction Manual
Features
Normal display: Hour, minute, second, days of week
Stopwatch stage timekeeping function
Alarm and Snooze alarm function
Hourly chime function
E.L. back light function
Buttons: Upper left "A"; Upper right "B"; Lower left "C"; Lower right "D"
To Set Time/Calendar
1) In Normal time mode, press "C" three times to enter into Time Adjust State, the seconds digits will flash, press "B" to set the seconds
2) Press "D" change the next selection in the following sequence:Minutes-Hour-Date-Month-Days of week.
3) Press "C" return to Normal Mode
To Set Alarm Time
1) From Normal Time Mode, press "C" twice to enter the Time Alarm
2) The Hour digets will flash, press "B" to set the hour value.
3) Press "D" once, then press "B" again to set the minute value.
4) Press "C" to return to Normal Mode.
Stopwatch Operation - Event & Time - Out Timing
1) From Normal Time Mode, press "C" once to enter Stopwatch Mode
2) Press "B" to start Stopwatch.
3) Press "B" again to stop Stopwatch.
4) Press "D" to reset Stopwatch to 00.
5) Press "C" to return to Normal Time Display.
One-Two Fast Finish-Timing Two Racers.
1) From Stopwatch Mode, press "B" to start Stopwatch
2) Press "D" when the first racer crosses the Finish Line.
3) Press "B" when the second racer crosses the Finish Line. Record the time on
the display, then press "D" to get the second racer's time. Record the time.
4) Press "D" to reset the Stopwatch to 00.
Alarm Time & Hourly Chime Function
Hold the "D", then press the "B" to on/off Alarm Function and the Hourly Chime, when Alarm On, the signal will display on the screen, when the alarm ringing, press "B" to stop ringing, it would ring again after 4 - 5 minutes, press "D" to stop again-ringing.
E.L.Backlight Function
In the Normal Time Mode, press "A" to turn on the E.L.Back light, it will auto stop 3 seconds later.
Battery Replacement
LR1130 for NEL621 & NEL15AES
LR1120 for NEL611
Posted on Nov 03, 2012
How to set the day of the week
here is your manual (I think)
http://cdn.invictawatch.com/invictawatch/website2014/webroot//uploads/manuals/2-8040n-pdf
If not, their site is pretty good.
http://invictawatch.com/service/view-the-instruction-manuals
nice video but as good as a chocolate teapot!
https://youtu.be/iv0aXQNH4yY
anyway, here is your info
Invicta Watch Setting Instructions By Ashley Brown eHow Contributor Found This Helpful A watch is only useful if it displays the correct time. Over time, your watch may display the incorrect time as the battery wears down. After installing a new battery, you will also need to reset the time. All Invicta watches have similar instructions for setting the time. Setting the time does not require any tools or equipment.
Other People Are Reading
Watches with Time Only
  1. Pull out the crown. The hour and minute hands will stop.
  2. Turn the crown until the hour and minute hands are positioned on the correct time.
  3. Push in the crown to start the watch.
Watches with Time and Date
  1. Pull out the crown to the first position. The crown can be pulled out to two different positions. Pull gently once to reach the first position.
  2. Turn the crown until it reaches the correct numerical date.
  3. Pull out the crown to the second position.
  4. Turn the crown until the hour and minute hands correspond to the correct time.
  5. Push in the crown twice. It should now be resting firmly against the watch, in its original position.
Watches with Time, Day and Date
  2. Turn the crown to reach the correct day.
  3. Turn the crown clockwise to reach the correct date.
  4. Pull out the crown again to the second position.
  5. Turn the crown until the hour and minute hands display the correct time.
  6. Push in the crown twice so it rests against the watch. The crown should be back in its original position.
Read more : http://www.ehow.com/how_7352591_invicta-watch-setting-instructions.html
Sep 13, 2015 | Invicta Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
Change 12 to 24 hr & date
Hi bobwesley,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 17, 2010 | Timex 1440 Nylon watch
How do you set the time and date on the addidas
If you haven't got the instructions,you can get them from their web site (www.adidas.com/campaigns/watches_fw07/content/index.asp?)
Click on "instruction manuals" in the menu on the left, choose your country.
You will be presented with a series of generic instructions from which you should choose the ones that suit your watch
May 02, 2010 | Adidas PEACHTREE watch
My me1020 came without instructions and i do not know how to set the date, min nor theday please help
Actually there is no instruction manual for ME1020 available on Fossil website except for how to replace the battery. When you try to match ME1020 model with the available diagrams, there is no match (4 eyes). To set the time, pull the crown out to the second position. Now set the min/hour hands. Date hand is linked to it so keep rotating the crown till the date is set is set correctly. Now remaining is the day setting. Notice that the day changes every 24 hour mark on the 24 Hour sub-dial, so cross this mark to change the day. Go reverse & again cross the 24 hour mark to get the next day. Repeat this till you get the correct day setting. Now your day is also set along with date & time!
Feb 14, 2010 | Fossil ME1020 watch
Setting time and date for Citizen BT0010 54E
Use this link: http://www.citizenwatch.com/COA/English/settings.asp Fill in requested details of your watch and click on GET SETTING INSTRUCTIONS, then click on INTERACTIVE SETTING INSTRUCTIONS. There you will find everything you need to set up your watch. You can download instructions on this site as well.
Rate me, please.
Jan 11, 2010 | Citizen Watches
CAN YOU EASILY EXPLAIN HOW TO SET ME TIMES 1440 SPORTS WATCH. SINCE TIME CHANGED WE ARE UNABLE TO SET AND CANNOT FIND INSTRUCTIONS THANK YOU
Hi garysuzie,
To set the digital time and date on your Timex, please follow the steps below.
Hope it helps.
Nov 03, 2009 | Timex 1440 Nylon watch
I would need to set the time on my timex WR50M watch and I have missed place my instruction sheet. I would need th instructions Thank You
Hi fuscoromeo,
Timex Digital Watch
Hope it helps.
Nov 02, 2009 | Timex 1440 Nylon watch
Tozai digital watch-setting correct time/date
I need to correct the time/date setting on a tozai digital watch.
Apr 05, 2009 | Watches
Timex Indiglo Acqua watch
For analog Acqua watches adjust date when month has less than 31 days:
3-Position Crown: Pull crown to "MIDDLE" position and turn CLOCKWISE or
COUNTERCLOCKWISE until correct date appears.
2-Position Crown: Pull crown to "OUT" position and turn CLOCKWISE until date
changes (approx.1:00 a.m.). Then turn COUNTERCLOCKWISE to 7:30 p.m. Repeat until correct date appears.
Dec 05, 2007 | Watches
Bulova Watch Logo
4,280 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
