Replacing 10up @16volt caps on toshiba hyperboard help toshiba 42
Hi i have soldered and desoldered resistors anf fuses but im not sure how to desolder and solder these capcitors on a toshiba 42h82 hyperboard
what do i doesnt look like pins sticking out like res and looks like little "houses" or raised rectangle/squares
  • 1 more comment
  • dcxguy48080 Jan 09, 2009
    thank you
    do you know which ones to repalce for the squiggly line wavy pic issue on these toshiba tvs?
    which locations?? on this hyperboard
    thanks i found a pic online in another forum...but again can you tell me
    i have done resistors and fuses before very easy for me
    with these you said im not actually using a desolder tool??
    you said to just heat up and pull out and then heat up and install???
    no removal or adding of solder???????
    so you are desoldering and resoldering correct?
    and is it just 1 pin or how many pins or 2 or 3 or 4....
    on these CAP 10UF 16V ELECT WX SMD
  • 73 Answers
They are just little box reservoirs. Heat them up and pull it out when hot. Heat it up again and set the caps in the hot solder box.
Posted on Jan 09, 2009
  • charles durando Jan 09, 2009
    I don't but someone here may if you repost your second question separate.
    You should be able to find it though if you have a oscilloscope. Each resistor will have a value based on
    the color bands around. you can check these values and if any are dead, theres your culprit.
    Best Regards,
    you can use a de soldering tool.
    I'm sorry I forgot to mention that.
What does the hyperboard look like
The actual board is in a box, careful the four metal pins must be un-soldered to remove the unit from the main board.
Nov 30, 2012 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H82, no sound after fixing hyperboard.
Search for the audio amplifier - it's a chip with a radiator on it - the jack for the speakers should be close by.
Jan 09, 2010 | Toshiba 42H82 42" Rear Projection...
Toshiba 57hx81, has a slight squikgly line near the top of screen, colors seemed faded, not bright. i did the convergence adjustment and adjust the colors/focus with front lower right screws..Is there a...
jhinsincity: you dont need to be here, do you? the problem are the caps on the hyperboard, 10 -16v@ 10uf, rear access right hand green board, model 57hx81, the hyperboard must desoldered from main board. read the post on wavy lines,,
Dec 30, 2009 | Toshiba 57HX81 57" Rear Projection...
It Is Fuzzy and the picture jumps around until it warms up but when put in picture in picture the 2nd picture is clear
you need to have a tech replace 10 caps in the Hyperboard there is a service bulitin on this on the toshiba web site
Nov 23, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba 50HX81 Power LED Flashing
Check any/all soldered-in micro fuses....F850,F851 etc.
Re-check your work......
solder jumper wires on signal board or fuse (s) may blow......T.
Apr 20, 2008 | Toshiba 65HX81 65" Rear Projection...
Hyperboard repair Toshiba TSB
Best way is to check in circuit with ESR meter........
EDS-88 CapAnalyzer..... .........................
Mar 27, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba 57h81 location of hyper board and remove procedure
Hyper board is located directly behind the input board, this is where all the tv conections are, then they are two tabs soldered from the bottom of the board then it simply unplugs, But replacing all those capacitors on that board can be a little tricky, replace all 10up @16volt caps and that usaly repairs the board
Feb 12, 2008 | Toshiba 57H81 57" Rear Projection...
Wavvy lines, wiggy
Dougers, I am next door, in Alberta. I have fixed my hyperboard by replacing the surface mount caps myself in my workshop for a fraction of the cost of a replacement board.
See my other thread for more information.
Oct 23, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 50h13 hyperboard
You need part #23148024.  The part is NLA.  I have 1 in stock or you can send yours to PTS electronics 800-844-7871 for rebuild.
Oct 15, 2007 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
283 people viewed this question
Top Televison & Video Experts
