Question about Harley Davidson Road Tech HA90 MP3 Player
Hear a knock at idle 06 roadking
Hear a knock at idle seems to go away once you pass idle
  • 91 Answers
Check your primary chain adjustment if it is excessively loose or the motor nut is loose it will knock at idle and when you gas it the noise goes away check this first you will need to remove the primary cover
Posted on Jan 11, 2009
2003 deville car knocks at idle when u drive engine knocks a lot less almost cant hear it
when was the last time it had the oil / filter changed ? change it and see if it goes away, weak oil will damage the engine and a contaminated oil filter will stop working.
Mar 17, 2014 | Cars & Trucks
Car knocking
big ends camshaft water pump
Oct 28, 2013 | Cars & Trucks
Knock in oil pan when idling
Sorry to say it sounds like a rod or main bearing going bad.
Jun 30, 2013 | 2002 Ford Explorer Sport Trac
Continued knocking while driving. Seems to knock faster as I accelerate, but does not knock at idle in neutral, starts to knock when reviving at 2200 rpms
Well lift the car up and put it on drive wile you can hear what the knock is. See if is your engine or the transmission. And if ok check your spark plugs make sure you getting fire to them
Feb 26, 2013 | 2001 Volvo C70
Knocking noise on idle
Most likely the rocker shaft end float that needs to be adjusted.
Apr 16, 2012 | BMW R 1200 GS Adventure Motorcycles
The engine is making a loud noise towards the bottom of the crankcase. but when i raise the throttle it goes away
check engine oil pressure first .how is the oil pressure? is it low ?
when you raise the engine speed and bring it down to idle fast ---do you hear the noise? Do not do that at high speed and only once or twice or may do more damage to the engine. If you hear the noise ---"knocking" ---than it sounds like a loose connecting rod bearing ----means you need your engine rebuilt or replaced.
Jan 18, 2010 | 1993 Ford Tempo
Knocking sound i only hear it inside it is a KZ 1983 7
The fuel tank will be the magnification point because of the liquid and thin sheet metal. It could be a fuel knock whick should go away at yhe bike burns off any excess.Check your oil for the order of ga and any metal content. O had a Yamafa 350 that Ran me down that road untill O discovered the fuel was free running and flooding the ctap out of a cylinder. Run the bike awhile and if it clears up, Chk tomake sure the tank petcock is not on pri. or res.If it has a three position pet **** and it is vacuum controlled, It can allow fuel to pass through the vacuum line unrestricted if the diaphram is damaged.
Jun 13, 2009 | kawasaki Z 750 Motorcycles
2002 s10 manual trans 2.2 engine knock (low end?)
check out your knock sensor , just a thought.
Mar 07, 2009 | 2002 Chevrolet S-10
Knocking noise at idle and accelearation
did you buy it privately or a dealer w/ a warrantee? If you have a warantee, use it.If not start by changing the oil& see if that gives you any results.use the proper oil for Subaru,not a Quick Lube.
Feb 16, 2009 | 1999 Subaru Forester
'99 Forester with a knocking noise at idle and acceleration
sounds like you have a headgasket blown, a head, or your rocker arms or lifters whatever you prefer to call them are running dry. might be time for oil change and coolant flush. If ther is no overheating or coolant smell than get your injectors checked. You might just have a broken seal that emits louder sound from the pulsating injectors. Good Luck!
Feb 16, 2009 | 2000 Toyota Corolla
Open Questions:
See all Harley Davidson Road Tech HA90 MP3 Player Questions
Harley Davidson Road Tech HA90 MP3 Player Logo
374 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
