Question about Apple iPhone 3G
The Battery on my Apple Iphone 3G
Is completely horrible. After a full night charge (approx 6 hours) with no use during charging, my battery life decrease by 1/2 just from listening to my ipod and responding ti a couple of emails during a 45 minute train commute to work... and yes, I had the WIFI setting turned off... Is there anyhing I can else I can do to preserve/extend/maximize battery life
    President:
  • 239 Answers
Hi, I just published a guide to help you maximise your iPhone battery life. There are several good tips in the article. Here it is
http://www.fixya.com/support/r4079271-tips_hints_maximise_iphone_3gs_battery
Hope it helps.
Jim
Posted on Feb 08, 2010
  • Apple Expert
  • 89 Answers
U better put ur mobile brightness low
Posted on Aug 26, 2009
What are the main power and battery differences between iPhone 4s and iphone 5S?
Both Apple products have a built-in rechargeable lithium-ion battery that can be charged via USB from a computer or power adapter.
The Apple iPhone 4S battery allows:
8 hours of talk time on 3G
200 hours of standby time
6 hours of internet use on 3G, 9 on wifi
The Apple iPhone 5s battery allows:
10 hours of talk time on 3G
250 hours of standby time
8 hours of internet use on 3G, 10 on LTE and 10 on wifi
Both provide 10 hours of video playback and 40 of audio.
Sep 11, 2013 | Apple iPhone 5S
Iphone 4 battery
If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.
1. Decrease the screen brightness of your phone.
2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )
3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )
4. Turn off bluetooth.
5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
Feb 25, 2013 | Apple iPhone4 4G iPhone 4
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
I bought a portable charger for my iphone 3gs, my battery was getting low so i put this charger in and now my phone wont switch on?
The charger may not be compatible with your iPhone and the battery on your phone may be completely discharged.
Use an OEM (Apple iPhone) charger and see if it charges your phone. Do not unplug it until it is completely charged (several hours).
Dec 15, 2010 | Apple iPhone 3G
My iPhone will not recharge after running out of
From what i see here, this could be a battery issue, you can have your iPhone's battery changed, if you said that the phone have done this twice already and this would be the third time, I could tell its battery problem.
Also it could be software or firmware issues,.
i would recommend that you bring your iPhone for immediate repair, I cannot recommend also dismantling the unit yourself, because the iPhone have so much delicate and sensitive parts inside and if the person that would dismantle it have no experience at all, may lead to more serious damages.
Jul 06, 2010 | Apple iPhone 3G
Battery life less than 12 hours; Wifi says "UNABLE TO CONNECT"
This is a really good article that will take you step by step through the settings that will best optimize your battery life. And if this doesn't help you should make an appointment at your local Apple store, they are always very helpful (at least in my experience).
http://www.apple.com/batteries/iphone.html About iPhone BatteriesLearn how to maximize the lifespan and battery life of your iPhone.
Nov 09, 2009 | Apple iPhone 3G
Battery life is so short and it takes 10 hours to fully charge it
this problem must not come in iphone. i bet you have a faulty product. contact service center immdediately.
Jul 27, 2009 | Apple iPhone 3G
My Iphone 3g wont hole a charge for any amount of time. I charged it for most of the night last night and it was fully charged at 7 this morning now a 9 it is almost dead
Your battery is deteriorating. Send it in to apple to get it replaced-
$40- 50. when back, fully charge and discharge 5-10 times, and do NOt leave it constantly plugged in.
Jul 15, 2009 | Apple iPhone 3G
I have been given iphone 3G but the user manual is missing.How do I charge the set and start operating it.
Plug in the cord in the socket and charge..its simple..nothing to worry but make sure its charged fully in the beginning as normal phones then use it almost complete b4 recharging as it will increase the battery life.
Mar 22, 2009 | Apple iPhone 3G
IPhone 3G battery problem
My battery on my iphone used to only last a day when limiting my use. And when I tried to use it normally with all the apps and music and calling people it only went for 10mins and then turned off.
How I fixed this:
It's an ongoing solution. I charged it up until it said 100%, then used it all up until it shut down again. And then I charged it til 100% and then depleted it again. Repeat over 2 weeks and your battery life should get back to normal. It worked for me and now my iPhone works better than ever!
Jul 21, 2008 | Apple iPhone 3G
Apple iPhone 3G Logo
143 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
