Question about Delta Model 300: Classic Single Handle Kitchen Faucet - Chrome
When turned on to hard the water sprays out the back of the facet
The Delta model has a single plastic round handle and when one lifts it to high up the water sprays out behind the facet. Can I have a diagram of how to replace this with a kit. Already purchased kit and new handle at Home Depot but want some help
    Genius:
  • 1,605 Answers
Turn of both water supply under the sink.
there is a small red/blue plastic cap at about 45 degree to the underside of the handle. you need a allen key screw driver to lossen it, then pull up the handle. unscrew the lock cap on top of the facet body. left out the cartirdge and make sure there are two "O" ring at the butom of the cartridge is out of the focet body. install in reverse.
Posted on Jan 09, 2009
After replacing seats & springs, no water will come out of spout. Sprayer works fine. Put old seats & springs back in & same problem.
need to put in little round ball back.. the right way..make sure ball is in right before putting hold down holding piece w notch in it
Nov 21, 2010 | Delta Faucet Delta 470-BL-DST Signature...
Facet still leaking after replacing the RP4993G part.
Make sure the area below where you replaced that part is free of scale and is not damaged in any way. Scuffs, scale and dirt will caused your leaking.
Sep 13, 2010 | Delta Faucet Delta 470-BL-DST Signature...
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
How do I remove the cold water handle?
You will need a set of std allan wrenchs.There should be a small set screw behind the portion of the handle that you grab onto .Its not nessisary to remove it,only loosen it.Then gentlypull and wiggle the handle ,it should come right off.
Dec 11, 2009 | Delta & Single Handle Shower Faucet
Leaking Delta bathroom facet
Is this single handle?If so, you need a allen wrench to take handle okk.But come to think about it you get the tools with the repair kit.
Mar 13, 2009 | Plumbing
No water comes through after installation and turned on supply valves
these facets are shipped with plastic plugs in them to keep stuff from getting inside them during shipping. Did you remove the plastic plugs where the supply lines hook up?
Jan 04, 2009 | Delta Model 300: Classic Single Handle...
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
  2. Remove handle.
  3. Remove top cap.
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Delta Model 300: Classic Single Handle Kitchen Faucet - Chrome Logo
273 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
