Question about Kenmore 24032\24036 Top Load Washer
Cold Water won't shut off
When my washer is filling, the cold water won't shut off. The washer begins agitating and the cold water is still running. I have to turn off the cold water at the faucet and then turn it back on again when the rinse cycle begins.
    Sergeant:
    Champion:
  • 262 Answers
Hi momma, sounds like the water inlet valve has got debris in it if it dont stop when the washer is off either then that is the trick the water inlet valve is where the hoses hook to the washer for the water to com in.if it oes stop when washer is off check and see if power is coming to it from the time while machine is off if you have power then it is the timer.now if the water will stop the hot only?during warm setting ? if only on cold see if the hot will stop on the hot setting if it dont replace the water level switch in the consol the on that controls the level not the temp if it does check the frist two let me know what you find out and i will help you get thru it
bill
Posted on Jan 09, 2009
    Sergeant:
    Novelist:
  • 326 Answers
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to.
    Sergeant:
  • 378 Answers
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
    Master:
  • 416 Answers
Probably it is faultywater-level switch
A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Good Luck
  • 13,433 Answers
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
    Top Expert:
  • Kenmore Master
  • 77,194 Answers
U will need to change the cold water valve, very cheap and available from any appliance repair center like Sears.
    Genius:
  • 3,422 Answers
HI,
Please , try by removing cold water hose direct the hose into a bucket and fill the tub on the warm setting (flushing the cold valve) then try the washer again.
Let me know the result.
  • Priya darshan Jan 09, 2009
    If it keeps filling you have a fill valve that is stuck open, if it
    stops filling there is something wrong in the water level circuit like
    a stuck fill level switch or the hose to the switch has come loose or
    has a hole in the hose.
    IF you still face the problem then you will have to replace the valve.
  • Kenmore Master
  • 19,396 Answers
That is because of a faulty inlet valve, only sporadically it is because of a defective control board.
The inlet valve must be tested, if it is fine then it is probably the control timer.
  • Ginko
    Ginko Jan 09, 2009
    If you have not done it before unplug the machine from power for few minutes, or trip the circuit breaker, this may not fix it but must be done.
    As I said the inlet valve is stuck on open, and the technician must read voltages at the valve and energize it to check if it closes.
    If the valve is faulty must be replaced.
    If it is fine, check wiring and control board.
    If water comes out during all cycle, it is not a water level switch.
    If you give me the model number I can find parts and schematics.
    help finding the model number on your appliance
Whirlpool washer letting both cold and hot water in when I only ask for cold water...
The water valve is working. It only does as told. Faulty water temp switch or yank out the small board and clean the terminals then re insert it and see if maybe corrosion was all that it was. That is what I would try if it was mine.
Dec 22, 2016 | Whirlpool Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Won't finish the final spin
    Post further comments for more information ....
    Good Luck!!
    Thanks
    Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    The washing machinge is not completing the complete cycle
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washer functions but doesn't fill with water, with
    if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
    replace the water level/fill switch for the fix.
    Phil
    Jun 10, 2009 | Washing Machines
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    As washer was on final spin cycle it sounded like a belt came....
    Apr 01, 2009 | Kenmore Washing Machines
    Maytag washer wont start after it fills
    Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
    Mar 14, 2009 | Maytag Washing Machines
    Kenmore 24032\24036 Top Load Washer Logo
    304 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
