Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
Screen want black
Similarly to the recent posting by bwb68, when I turn on the TV I hear the speakers click on and the red power light glows but there is no picture or sound. We were in the middle of Lemony Snickets when it just went blank. Other devices on the same surge protector kept working fine so I am concerned. I got this baby new in 11/02 and it has been good so far. Am I in big trouble or can I fix this on my own? I hate to spend the money on a repairman to tell me I am screwed. Help and thanks, Glenn plasmagrenade@yahoo.com
  • 2 more comments
  • glenn oswald
    glenn oswald Jun 07, 2007
    Thanks so much Bill. I am relieved to hear that I am not shopping for a new TV. You arre the best. I don't suppose you are in NJ?
  • glenn oswald
    glenn oswald Aug 09, 2007
    Finally got a repair quote - $550 to $650. They confirmed that it was the power supply and also mentioned two other parts that may be suspect. Anyway, this is way over my budget but I hate to scrap this investment.
    Are you sure I can't do it myself?
  • Anonymous Nov 12, 2007
    hello i have had my bigscreen for 5 years now ...and has done the same thing snapping and going off and on not sure what it was myself?? you have come up with power supply..i to did not want to discard my set they are expensive!!! who can fix these for us?? and you say 550 to 600 to fix??? ifound that parts on the mother board are burnt and the snapping was arcing on the board called tv repair got # off board called suplier with #he says NLA no longer exists!!!can i buy a new board??? brian
  • prolog Nov 12, 2007
    had same prob. with my 65 in looks as if board around power supply is burnt took board # pd 0640 and called tv repair they called suplier they told tv repair nla no longer avaiable??? is this true??? help!!!! brian
  • 934 Answers
Well you've come to the right place - - even though this is one you probably can't fix yourself this "repairman" is here to tell you that you're not screwed either... From what you've explained it sounds like the SMPS (switch mode power supply) or something in the B+ volatges are at fault. The fact that the TV does power means that your lower voltages are still working and the x-ray protection circuit is probably keeping the unit from doing any critical damage to itself. So, my best professional advice is, have an expert look at it.. As a couple of tips: (1) Find a good reputable shop. Call NESDA and ask for phone numbers to some or their member shops in your area. (2) Take the unit to the shop yourself. Have a buddy help you load it in the back of a truck, strap it down, and take it in.. Much of the cost will be in transporting. (3) Have it estimated before any repairs and know ahead of time what the shop charges to estimate the job. (4) Ask to have the technician save all the old parts and compare those parts later with what work is outlines on the final invoice. The kind of repair you have there is something I do every day, sometimes two and three times a day - - to TV's that are far less worthy. Hope this helps! Bill
Posted on Jun 06, 2007
SOURCE:
I have the Toshiba Theaterview. Was watching it when I heard a sound and the screen went black. The Red Light will come on and glow steady and you hear it click when you try to turn it on or off but...
Something is causing the TV shut down or go in to 'protect' mode.
It is unusual to actually hear a component inside the TV go bad, but you obviously did. Probably in the main power supply or something that normally uses a higher voltage in the TV since you heard it..
Jan 25, 2015 | Toshiba Televison & Video
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
How do I check the led light strips on my led lcd tv, to see if they work? and/or how do I replace the led light strips?
Contact any service technician. It will be best in this case. If you're sound in electronics, and have some previous knowledge in servicing LCD TVs; please respond. Otherwise please !!!!!!!!. Time is precious for us.
Jan 18, 2015 | RCA Televison & Video
TV powers on with no splash screen and then powers off.
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 14, 2014 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Blank screen panasonic plasma tv
The solid red light and the glow of the screen indicated the set is on . also if set is on a red light should be emmiting from the optical out jack. Seem like you have lost audio and video. If no menu appears when pressed on remote the replace the main board. Panasonic calls this the A board.
Jan 06, 2014 | Televison & Video
Screen does not turn on, but power still has power to light the blue light and do the Samsung turning on chime...
Take the back off and look for any blowen fuses. If still under a warranty, DO NOT OPEN THE BACK and take it too the shop!
Nov 25, 2012 | Televison & Video
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
Digistar PH-4210D Black Screen
Plasma tvs do not have "back lights" LCDs do. you probably have a bad driver board along with the upper or lower buffer board or maybe both, best to have a tv shop look at it.
Aug 30, 2009 | Televison & Video
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
TV won't power on
I am from Australia and this TV is a dud. We purchased it 12 months ago and it has been to repair twice. It is doing the same as the above message. Prior to this the screen would half, horizontally, go black or white with coloured vertical lines. Never buy another of these.
Dec 22, 2006 | Philips 42PF9966 42 in. HD-Ready Plasma...
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
