Question about LG WM-2077C Front Load Washer
Washer makes a loud squealing sound when starting water cycle
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
This means the electronic water valve has gone bad and will need replaced by a technician. Hope this helps, please rate my solution.
Posted on Jan 11, 2009
SOURCE: loud squealing sound
It is the pump going bad.  There is a tech sheet inside a ziploc bag beneath the control panel.  From the front of the machine, lean over it and look just behind the control panel and locate the two silver screws towards the outter sides.  Remove those two screws and lift the control panel off.  Next to where the water hoses are connected you'll see a ziploc bag with the tech sheet inside.  It has instructions on how to put the machine into diagnostics mode.  Do this if you want and it should tell you the pump is going bad.
Our GWL11 was making that same noise and I just let it go because the machine still worked and, quite frankly, I had no idea what the heck it could be.  Though I'm handy, I've never attempted to fix a washing machine.  Boy, I wish I would have researched the issue online sooner.
After spending more time online researching this issue than any person should, it turns out that squealing noise is the pump going bad.  A fairly inexpensive (about $75) and easy thing to replace.  Should only take 15 minutes or so to change out, even if you've never done it before, and that includes the time to disconnect the hoses and manually bail out the machine.  But if you let the problem go the pump will eventually short out and in turn take out the controller board with it, which is about $130+ just for the part, and you'll have to replace both.
We got about a month of use out of the machine with it squealing then one day it just up and quit.  It would not power on at all.  I did all the unplugging, waiting 30 seconds, plugging back in, etc... and nothing.  Sure enoung the pump shorted out and took the controller board with it.  I actually just received my new pump Saturday (5/16/09) and replaced it yesterday hoping that would solve the problem, but alas, it still won't turn on.  Now I have to buy a new controller board...sigh...
Change the pump now and save yourself some headache and money.  If you have a model GWL11 the pump part # is 420325P.  Should you need the controller board too, it is part # 420094USP.  Good luck!
Posted on May 18, 2009
Buffalo12980
  • 625 Answers
SOURCE: Loud noise
sounds like the absence of lubrication in the transmission. could be a bad bearing on the pulley side
Posted on Sep 25, 2007
  • 686 Answers
SOURCE: My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Posted on Apr 06, 2009
milten1
  • 1304 Answers
SOURCE: WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Posted on Oct 13, 2009
miket756
  • 2702 Answers
SOURCE: WASHER MAKES SQUEAKS AND SOUNDS REAL LOUD DURING
it could be a split pipe but its far more likley to be the drum bearings on the way out thats why its so loud and thats also were the water is coming from as well
not a cheep repain to get done,,,
sorry for the bad news
Posted on Oct 25, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Hav3460aww
It sounds like the motor is heating up and tripping the overload. The squealing is probably coming from you pump. Tilt the washer back and turn the pulley for the pump by hand and if it make the squeal, replace. If it does not you may have a bad transmission.
Apr 28, 2014 | Maytag HAV3460AWW Top Load Washer
Loud squealing noise from water softener when toilet flushed
The unit may be in a regeneration cycle during the day. Reset to proper time of day.
It also sounds like you may need an air arestor installed on the plumbing in the house. When air becomes trapped in the plumbing lines it can cause the plumbing to "hammer" during periods of heavy usage. You would need to contact a plumber for proper placement of this device on your plumbing system.
RJ
Nov 28, 2013 | Valumax 5600SXT 30k Water Softner
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Squealing when filling.
there is a loose washer in the valve and the water is gong behind the washer therfore makeing the sound,, change the shut off valve and you will no longer have a sound,, good luck,, and make sure you trun off your waer to your house before removing the valves
Jun 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Loud noise
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
LG WM-2077C Front Load Washer Logo
654 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
