FixYa.com
Tags:
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
How to replace pump for 7901 bissell pro heat steam...
posted by antlers on Jun 04, 2007
My brush would not turn and I noticed that something red had melted where the belt was suppose to be turning. I took the part to my local repair shop and they sold me a replacement pump. There's a problem. I don't know how to get the old pump out. I don't see any screws or anything. How do I get the cover off the top in order to replace the pump?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 13, 2007
FixYa! (100)
1952
Rank:Wiz Wiz
Rating: 85%, 63 votes
unplug unit first
take six screws out of housing.
lift of housing.
you can see pump at front of machine.
four screws hold pump in.
make sure all tubes are routed correctly.replace housing,
make sure no tubes are trapped
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 05, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Solution #3
posted on Jun 18, 2007
Thanks for Trying (70)
Guest
Guest
Rating: 0%, 0 votes
Quite complicated and if taken to a repair dealer the charge is very high.
Solution #4
posted on Oct 28, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
dont replace the whole pump just the red thing
Can you Help with these Vacuums problems?
Bissell 7901-1 ProHeat Scotchgard Upright...
it no longer sucks up the water
in the frount of the carpet... Answer This...
the cleaning solution stoped...
the cleaning solution stoped... Answer This...
cleaning solution
cleaning solution not coming... Answer This...
no cleaning solution/water...
Replaced pump when shaft... Answer This...
bissell 7901 proheat service...
my deep cleaner no longer spays... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
