On my samsung tv I Have the screen divided in the middle vertically with overlapping and reversed images on each side. It is the same regardless of input and the tv has the same problem when viewing the menues. I have 2-3 overlapping pictures horizontally (not rolling), but vertically the images are ok. What needs to be replaced???
T'Con board should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
SOURCE: Screen shows several horizontal and vertical lines.
Press the menu on the TV and let me know if the menu is effected. If the Menu if effected , you can try unplugging the power cord for a minute and replugging it back. If the issue still persists , a physical diagnostic is necessary to determine the exact defective part on your device. It could be a problem of main board or even worse, the panel.
SOURCE: In my samsung 40
It could be the power supply causing this problem - puffed caps in the Power Supply and low voltage to the signal board. Have both checked.
SOURCE: Samsung ln t4661f picture issues.
We have the same problem. I am afraid it is a defect that is occuring in the samsung tv's
SOURCE: I have an Samsung LE52B750 TV that it has
Hello, it sounds like one of the display boards has gone. Its probably not the screen as you wouldnt get any picture at all or very little. Even though it sounds expensive, most of the work is in dismantling the tv. These days its just a matter of replacing a board or two. Get two or more quotes and pick the best one. I hope I have helped.
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
