Question about HP PhotoSmart C4480 All-in-One Printer InkJet
Excessive use of ink
My new Photosmart C4485 gets thru cartridges at an extraordinary rate despite B&W settings at 'fast draft', overspray set at 'least', ink volume's set at 'lighter'. Colour printing all at 'fast normal'. Previous PSC1317 lasted 2 months, this one 2 weeks... for my normal use! Any advice. Is this what I should expect from HP. Refill cartridges seem to be rejected by the machine! Are there other printers that are not so thirsty? Costing me a fortune!
    Genius:
  • 2,120 Answers
Sorry, HP's main objective is to sell ink.
Posted on Jan 10, 2009
The printer takes a long time to print.
Buy a faster printer.
And, no, I'm not being a smart-aleck
HP rates this printer at up to 32 pages per minute -- in fast draft mode black ink only... But even their ratings show it takes over a minute per page when doing quality printing in color.
And those speed ratings are all "after first page" -- ALL printers take longer for the first page due to the time it takes for the computer to set up the page and process the information.
As the specs suggest, you can get faster printing in black-only instead of color and by choosing fast draft mode instead of quality or normal mode.
There is very little that could be wrong with the printer that would make it print slower than usual -- generally any problem would make it not print at all or cause it to print incorrectly. Generally speaking whatever speed you see is simply the speed of the printer itself based on the settings you have selected, the software you are using, and the speed of your computer.
You can refer to the information on the HP website. It is just possible that replacing the printer driver MIGHT help but other than that there simply isn't much you can do about the speed of this (or any) printer unless you want to choose a lower quality print setting.
HP Photosmart C5250 All in One Printer Product Information
Mar 08, 2014 | HEWLETT-PACKARD photosmart C5250...
Hp photosmart 7760 the prints will not dry
hi
goto the cntrol panel--->printers and faxes--->right click the printer icon
click on the printing preferences and check the print quality ,try to set it to fast draft...this should save the ink as well as dry it faster.
hope this works
Jul 14, 2009 | Office Equipment & Supplies
My ink levels show full but when I try to make a copy it comes out extremely light or no copy at all. Help?
Press the Setup Button on Front panel
Scroll to Tools
Choose Clean Cartridge
Let it go thru the process
Try to Print again..
You can go thru the Cartrige Cleaning from HP Solution Center
Open HP Solution Center
Click on Settings
Click on Printer Toolbox
Click on Clean printheads
Do Intermediate and Prime cleaning depending on the Quality of Printout
If the Issue Persist :
Open Control panel and Printers and Faxes Folder
Right click on HP printer icon and Click on Printing Preferences.
Check the Quality is set to Draft mode or Normal mode.
Jun 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Not printing to fast draft
Make "fast draft" your default setting, otherwise, whenever you open a new document, it will print it in "normal mode".
Mar 09, 2010 | HP Photosmart 7450 InkJet Printer
It really prints so slow
Try setting the printing properties to fast draft or draft. It provides a average quality document faster using less ink.
To do this, go to Start->Control Panel and then Printers. Right click on your printer and choose printing preferences. Find the setting for the quality and select Draft or Fast Draft if it is available.
Please note that this printer has a rate of 5.36 pages per minute, so even with the draft you will not see much difference.
Regards,
nicolasiac
Feb 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
The ink cartridges need to be replaced very often epson 810
You can try to change your print quality to a lower setting. This saves a lot on toner. If you are not printing for anything super important you can set some printers to "fast draft" or "draft" quality and that saves a ton. I personally dont usually need to print anything of high quality so I went to my local "Everything" store(not sure if I should use company names) and bought an HP, the cheapest color printer they had which was $30.00 The black and color cartridges together cost about the same as the printer. But I use the lowest setting which is the "fast draft" setting and set it to print in black ink only, and only change that when I NEED something in color and it uses very little and prints very fast.
Aug 10, 2009 | Epson Stylus Photo 810 InkJet Printer
Won't scan, copy, or fax
You need to change the ink cartridge, the fact that it prints in fast draft is because it does not use as much ink to print as normal letter quality.
Jan 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Going through ink cartridges too fast
Check the capacity of the ink cartridges (in ml). HP usually has high-yield cartridges which cost more, but have more ink. Also check your printing preferences to see what your quality setting is. Draft quality is fine for most text and saves alot of ink, Normal or High is only needed for photo printing. I believe Normal is the default.
Dec 07, 2008 | Office Equipment & Supplies
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
103 people viewed this question
Ben Johnson
