Question about Philips 32PFL3403D/27 32 in. LCD TV
Not being able to change inputs
It is saying no label in the top right corner of the t.v. each time the input button is pushed on the remote then it goes to saying no signal
  • 362 Answers
Change the input setting on the tv not the remote.
If you are using a universal remote it may not be programmed correctly.
When you push the input button on the remote it is changing it to the Over The Air Antenna, it is not recieving a signal and there is no channel label added for the station it is set to.
If you do have an antenna connected, from the menu do a channel search and see if it can find any signal.
Let me know how it goes, I can assist further.
lone99star
Posted on Jan 09, 2009
Can anyone help me figure out how to change the source/input.
You should have a button on the remote labeled "input or source". Every push on that button will cycle through different inputs. Some inputs do not show up on the screen unless something is actually hooked up to that port.
Mar 16, 2016 | Coby Televison & Video
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
I can not get the emmerson tv i have to go into video mode. I do not have the origional remote that came with the tv or the manual. The remote i have is programed with direc tv. how do i get the tv into...
In the upper left hand corner of the DirecTv remote there is a button labeled "TV INPUT" just push that button. Each time you push it it will change the inputs for the TV. If that is not the problem, the remote needs to be programmed with a code for your TV. If that is the case push the MENU button under the circle in the middle of the remote. Scroll down to PARENTAL, FAV'S, & SETUP, push the yellow SELECT button in the middle of the circle, scroll down to SYSTEM SETUP, then scroll down to REMOTE and push the yellow SELECT button again. From there you should be right as rain. On my TV and setup, I have a device hooked up through DVI, but the TV won't recognize it unless it is powered on. In otherwords when pressing the TV input on my DirecTv remote it doesn't show the DVI device (PS3) unless it is powered on. I hope this helps and good luck. Please vote and leave a message.
Oct 30, 2009 | Emerson CR202EM9 TV
Blue screen No signal
Hi peed941,
Try pushing the input button on the remote, it sounds like you have accidently changed the input to anntenna.
Let me know if this helps and please rate this solution.
Lone99star
Jan 22, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Video Label
There's a "Display" button on your remote.  Push it.
Mar 29, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Can't change video input
TRY GETTING A UNIVERSAL REMOTE, AND CHANGE THE INPUT SETTINGS.... YOU MIGHT NEED TO DO A MANUAL CODE SEARCH SINCE IT IS NOT A COMMON TV MODEL.
Feb 21, 2008 | Televison & Video
Ds31590
njdb,
Look on the remote for keys that are labled tv/vcr or source or input... In fact, if you go to the front of the unit - that's a Sanyo right - find the grouping of buttons that change the channel, volume etc.. There should be a button marked source or input there.. Press it as many times as it takes to get back to the input source your cable is on...
If you have any problems let me know...
Bill
Nov 24, 2007 | Televison & Video
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Philips 32PFL3403D/27 32 in. LCD TV Logo
317 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
