Question about Dell E171FPb 17" TFT LCD Flat Panel Monitor
Inspiron 8500 laptop monitor; vertical lines & color bursts
When computer is first turned on vertical lines appear in different shapes either linear or zig-zag columns, then the screen will blotch out into different colors & black & white moving left to right across the screen. Eventually the screen either blanks out completely in black or different shades or sometimes faults to blue screen when in then dumps its physical memory. These are intermittent problems that have progressively gotten worse to the point that it now won't come up at all so the reguslar Windows desktop is visible. Previously this probelm was intermittent and sometimes the computer would clear itself and work properly even though in start-up the above symptoms were displayed for a couple of minutes until they cleared. It seemed to be heat related because it would work fine for an hour or two then fail. Now it's failing imemdiately. HELP!
  • 558 Answers
It sounds to me like you are having a problem with the video card on the motherboard, I am not familiar with this model but some you can remove the video card and upgrade, some you can not.if you can upgrade you can try this
if you cannot remove the video card then a new motherboard will be required to fix this computer.
you can look on ebay for a replacement at a reasonable price or talk to your local computer service center.
hope this helps.
Posted on Feb 04, 2009
Colored vertical lines on my monitor
Depending on the age of the monitor, it most likely will be Capacitors that are leaking. I have repaired many different brands of monitors and have seen problems very similar to yours. 99% of the repairs I do are capacitor Issues. It's well worth replacing them IF the screen is still in very good shape as far as brightness and contrast. most repair kits usually cost between 12 and 20 dollars.
Hope this helps!
Dec 08, 2013 | Acer Computers & Internet
Why does my monitor have colored vertical lines?
Hi Shannon,
I don't have good news for you. Coloured vertical lines is a symptom of terminal failure of LCD screens. Most common in laptops, monitors, and TVs. Problem only gets worse with time with more lines appearing, then expanding to cover a whole side of the screen. 30 - 50% normally.
Jul 19, 2012 | Dell Inspiron 2200 Notebook
Hi, I have a DELL Inspiron 8500. After turn on, I get vertical color bars - sometimes. Most of the time nothing. Connecting a TV for external monitor (VGA port) I get the color bars more often then on the...
the problem is with the gpu inside , i suspect that overheating or continual use of the laptop for long periods has meant that the solder oints holding the gpu to the circuitboard have started to short. Chances of repairing the motherboard are slim and a replacement will be needed.
Mar 14, 2011 | Dell Inspiron 8500 Notebook
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
Inspiron 1420 unusual colored line at bottom screen
yeap..itz the monitor's vertical roll over problem..
better to contact ur system admin/vendor, if u aren't an expert..!!
Oct 28, 2009 | Computers & Internet
Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
May 29, 2008 | Dell Inspiron 8500 Notebook
Vertical white line in center of monitor
Your monitor may have been cracked somehow...
Try restarting and look to see if the line is there immediately from the start or does it only show up when your operating system (windows/linux) loads?
Regards,
Chester
Jan 11, 2008 | Dell Inspiron 2200 Notebook
Dell E171FPb 17" TFT LCD Flat Panel Monitor Logo
344 people viewed this question
Alun Cox
