Question about Texas Instruments TI-83 Plus Calculator
Display is so light that I can barely read it, I've replaced the batteries and no change
I have a display problem, the print on the screen is so light that I can barely read it. I have replaced the batteries but it didn't make the numbers and letters show up better screen. Any suggestions?
  • Marlana Mardis Jun 04, 2007
    Thanks a bunch!
    That made it dark enough to read, thank you so very much!
    Scholar:
  • 48 Answers
Have you attempted darkening the display on the calculator through the function keys? Push "2nd" and then push "up" a few times. After resetting the calculator, this setting will always revert to a lower, unreadable setting. I'm sure TI knows about this, but they probably arent too inclined to fix it.
Posted on Jun 04, 2007
Proform 775 ekg control panel very dim, hard to read display
sounds like the back light is bad, not sure what type of screen that is. but most screens have a back light for them, they will go bad over time,
Apr 03, 2017 | The Computers & Internet
Is there a way to change the contrast as two of my units have a barely readable screen as the numbers are too light to read easy
Too light numbers usually indicate weak batteries. If you're sure the batteries are new then the display is done.
Jan 01, 2016 | Office Equipment & Supplies
Need to make print darker, hard to read
I have an old Kindle e-reader that I can barely read anymore. The text is not black anymore but light gray. There is no fix for it as it's simply a worn-out display. The earlier virtual paper displays had a finite lifetime of about 2500 hours I learned from doing research.
I bought a Kindle Paperwhite to replace it. I guess it will also wear out but hopefully technology has extended the time before it fades into oblivion.
Apr 08, 2015 | Tablets & eReaders
Gateway laptop powers up but screen does not come up.
Why did you replace the lcd inverter? Were you able to barely see icons on the desktop which is an indication that the lcd inverter is bad? If not, then you need to replace the lcd screen. If you could barely see the icons and you replaced the lcd inverter, then the inverter is bad. Just because the inverter is new does not mean it works. If the video shows on the external monitor, but you can't see anything on the laptop's screen even when you shine a flashlight on it then the lcd screen is bad.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your ideo card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad.
If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 24, 2012 | Computers & Internet
Why is my Gateway 4028GZ screen black
The display on this laptop is backlit. What that means, in a nutshell, is that the image on the display prevents the output from a constant light source (the back light) from showing through, thus giving a usable image on the screen. From your description, the backlight is no longer operating. This can be an issue with the LCD display panel, the backlight power module, our (less likely) a power trace on the motherboard. Repair would likely cost as much or more than replacing with a used laptop and just transferring your hard drive. If you choose to replace and swap hard drives make certain that the interface on the new laptop is the same as your Gateway's.
Jun 08, 2017 | Gateway 4028GZ Notebook
Display is faint and to light to read
Turn the calculator on. Hold down the "C" key (just above the ON key) and press + to darken the screen. If you go too far, use the C and - keys to lighten the screen.
Jan 21, 2012 | HP 10b Calculator
Phone display is very dim-can barely read
Well, first you will have to check your options, if you can read it enough to get in there.  You may have the backlight turned off.  If the backlight is not turned off, then you probably have a bad backlight and will have to take it to your provider to get it fixed.  Replacing a screen/backlight is not something I would attempt to do unless you are certain you know exactly what you are doing as you can render the phone completely useless.
May 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Display battery level
Well, I tried pressing and HOLDING down the mode button. The battery level display miraculously showed up. I’ve also read (yahoo answers) that battery level display will show up automatically when battery is low. Hopefully I won't have to do this every time I recharge the battery.
Mar 17, 2009 | Kodak EasyShare M1033 Digital Camera
My screen turns faint...
maybe try going to settings and click on battery and display and fix the light setting u have set on there if thats not helping then try calliing t-mobile
Jul 24, 2008 | T-Mobile Sidekick ID Cellular Phone
Texas Instruments TI-83 Plus Calculator Logo
452 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
