Question about Waring WMK300 Professional Belgian Waffle Maker
Unit gets warm but not hot enough to cause ready light to come on
The first two times the unit was used it worked, but on the third attempt to use it, it would not get hot enough to beep or cause the ready light to come on so we could use it -- No beep and very little heat.
  • dpriebe Jan 14, 2009
    I have the same problem. Used it 2 or 3 times, now the light comes on but no heat whatsoever. I emailed Waring website's customer service. I'll report any progress in a resolution.
    President:
  • 267 Answers
One of three problems . control board goes bad, high temp fuse burns out , wires burn through at element and burns out fuse and board ........ does not matter . no parts are made . i had a few if these come in a few years ago . people wanted them fixed ....... no parts then ...no parts now ........ call waring be mad , you might get something out of it
Posted on Jan 26, 2009
My konica minolta c250 is not ready but displaying warming up for a very long time and it did not ready still yet
Warming up means that the copier is not getting hot enough in fuser section, Secondly during that time certain internal house chores are done by the copier to prepare it for READY TO COPY. Are all the image units and toner cartridge OEM!!!??? second has each image unit and toner properly shaking ensure toner in toner cartridges and developer in the image units is spread evenly across each pull each out. shake side ways to ensure spread evenly, last time toner full was run nd gradation adjustments run ?
Dec 02, 2015 | Konica Minolta Konica Bizhub C250 Color...
Hot water varies
I do not know how old this unit is or what model but many water heaters are not sophisticated enough to measure the temperature, but heat based on water flow and temperature rise. To start, tankless water heaters turn off every time you turn the hot water off. Lets use an example. You use the facilities, wash your hands then turned off the water and take a shower. You will bring the already heated water (from washing your hands) from the pipe up to the shower. Then the cold water that comes into the pipe from the reactivation of the water heater comes up the hot water pipe with warm then hot water just behind.
If this is not your problem, keep reading. Every unit I have been called to see were installed wrong. Check your installation manual to see if the problem with the system started with the contractor.
First, check the temperature of the water from the heater. If it is too hot and you are mixing too much cold water in, the unit will turn off because there is not enough water flow to keep it running.
Second, turn off the valve at the water heater and turn on the hot water at a faucet. If the water does not stop running, there is a "plumbing cross over" usually caused by a failing pressure balance valve in a shower.
Third, if the unit has not been serviced, go to bosch-climate.us to find a tankless water heating professional in your area. Totally Tankless LLC
Mar 14, 2014 | Bosch & Tankless LP Hot Water Heater
This is only the 3rd time I've used it but is does not get hot at all. The light comes on but no heat.
If it is only the third time you have used it it should still be new, whatever it is. Take it back to the dealer under the warranty. Any attempt at a repair or adjustment will void the guarantee.
Jan 29, 2011 | Vacuums
I am getting a build up of black mold on the inside of the rinseaid compartment and all plastic pieces. Even in the bottom of the utensil basket. This has been happening for the last two months. Once I...
The first problem I believe you have is your hot water entering the unit is NOT hot enough. Turn up the temperature setting on your hot water heater. The water in your pipes should come out around 120 degrees Fahrenheit. That should be hot enough to burn your skin so use a thermometer to test. Second the internal heating coil may be burnt out or operating very low and may need to be replaced. For it to sterilize it needs to heat the inside to over 212 degrees Fahrenheit when steam is created. You should definitely make sure that the unit is drying your dishes and steam is spewing out the front exhaust vent during that cycle. Third the soap you use should be a better quality such as Cascade, or Finish. You may also try 2 TBSP of bleach during the WASH cycle. Which will also cause to sterilize.
The only reason you can be getting mold is lack of heat. If you are saying it is a recent problem then I would consider how old is the machine? And look toward the heating coil element.
If the heating coil is working, the washing unit may not be getting enough power. Make should the circuit is properly load rated so it is getting enough electricity to get it hot, hot, hot.
Oct 30, 2010 | Gaggenau GI966-760 Built-in Dishwasher
The first problem we noticed is the coffee is not as hot as it used to be, but it was still strong enough. Now the unit perks for about 10 min for a full pot, the light comes on....but the coffe is weak...
Hi, The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix. Thanks and please ask if you need more help. Ron For the part go to repairshack.com
Aug 17, 2010 | Faberware 10-22 Cup Coffee Urn
I've owned this saeco vienne de lux for about 3
Hi
When was the last time you descaled the machine? Scale will build up inside the boiler and insulate the water from the heating elements. The thermostat is on the outside by the heating elements so it gets hot but your water is warm. There are other things but check this first.
Nov 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Heater
The heater in your car depends upon a flow of hot coolant going through the heater core in order to get hot air into the car. If the heater core is partially plugged, it will restrict the flow. If you have a head gasket that is putting exhaust into the cooling system, it will eventually get into the heater core. When this happens there is no coolant in the heater core to make the air warm. If the water pump vanes have corroded away the result will be very poor coolant circulation causing the heater to not blow hot air. If your car is equipped with a heater control valve that is not functioning properly, the coolant flow will be restricted. One or a combination of these factors is likely the culprit in your case.
To attempt to clean the core, you must flush the system multiple times. If this does not work, the core cannot be cleaned and must be replaced.
Jan 16, 2009 | 1988 Buick Riviera
Coffee not hot enough
hi elite 288! have you tried pre-heating your coffee cups? i fill w/hot water, then set them on cup warmer until i brew coffee (dump out water & slide cup under spout at last moment) and i do my frothing of milk before brewing espresso. also, have you allowed adequate time for machine to warm up/run just water through machine: after it indicates it's ready to go, hit the brew button & allow about a 1/2 cup or cup of water to run thru, warming up the brewhead. when ready button again lights up, brew your espresso. if this doesn't get it hot enough for you, try descaling your machine (you can look online or in manual for how to do this). since you have a refurb unit & heating element may not have been replaced, it could have some build up on it causing it to heat up all the water less efficiently. if this doesn't work, you may need to have the place you purchased it from diagnose and repair. good luck!
Jan 11, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
I've just moved into a house and my Miele dishwasher only runs a cold to luke warm wash, and doesn't dry the dishes properly.
Hi Shachr,
I'm Harvey the Master Plumber.
Your problem is: You've just moved into a house and your Miele dishwasher only runs a cold to luke warm wash, and doesn't dry the dishes properly.
The d/w uses water directly from the hot water heater. Your problem is common when the pipe length between the two is long. By the time the hot water gets to the d/w it's already filled with the cold water that was sitting in the pipes. Don't dispare! Since the d/w is next to the sink, the next time your d/w is ready to wash just run the hot water till it's hot at the faucet then turn the d/w on, instant hot water for the d/w.
As far as your drying problem, this is common as the d/w gets older. In my humble opinion it's not cost effective to repair. I would be glad it's still washing, but it does mean it's time to start putting a littlr bit away each week and when it fails just buy new.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 15, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
Image runner 5020 will not print or copy
Hello Ernest T,
If the main thermistor which monitors the temperature of the fusing unit (that hot as hell area) is out of postion this problem can occur. The thermistor determines when the fusing area is hot enough to allow the copier to display"READY". If it is backed away from the fuser roller it cannot reliably read the temperature and it may cause the copier to display suspended because it reacting as if because of a long copy run it could not keep up the temp and so it "suspends" as it tries to ramp the temperature back up. Make sure the thermistor is touching the fuser roller.
Apr 16, 2008 | Canon imageRUNNER 5020 Copier
Waring WMK300 Professional Belgian Waffle Maker Logo
177 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
