Question about Philips 32PFL3403D/27 32 in. LCD TV
I work for comcast, i'm trying to troubleshoot one of your tv's with a cust. when trying to change the input channels, it says no label in the upper right corner and then it comes back to saying no signal, it does this everytime the input button is pushed to try to change the input channels
    Champion:
  • 240 Answers
This meens no signal is being recived.
tv might have problems.
Posted on Jan 09, 2009
Tv setup - cannot get past auto channel
Connect the TV to the Comcast box using an HDMI cable, then set input on the TV to HDMI - that's all. You then select channels on the Comcast box , not the TV (although the TV remote can be programmed to change channels on the cable box)>
Jan 27, 2014 | Element Televison & Video
I have comcast remote and granddaughter turned tv on side panel. Now screen is fuzzy and I can't find remote that came with tv. I get picture back?
Hello Mary and thank you for choosing FixYa today for your online technical support needs.
When you say the TV is FUZZY, do you mean that there is no picture there at all?
It is possible that your grandaughter may have changed the VIDEO INPUT MODE SELECTOR on the TV by accident when she tried to turn it on with the controls on the TV itself.
Most TVs have a button right on the front of the set itself labelled INPUT which allows you to switch between the various input modes. That button should be located right beside the POWER, CHANNEL, and VOLUME buttons on the TV's front panel.
You may simply need to press the INPUT button and select the proper INPUT SOURCE for your Comcast cable box.
The proper INPUT MODE for your particular setup will depend on how your Comcast cable box is connected to your TV. If your cable box is plugged into your TV with an HDMI cable, then make sure your TV INPUT MODE is set to HDMI.
I hope this helps out, and please feel free to comment back to this page with any additional questions or concerns and I will respond back.
If you do need additional help, please be sure to include the exact model number of your TV and of your Comcast cable box as well as how the two are connected.
Good luck and take care.
Joe.
Feb 14, 2012 | Initial DTV-201 20 in. LCD Television
MY TV JUST KEEP COMMING ON THE DVD PLAYER WILL NOY DISENGAGE
Not sure what you mean. The TV comes on and is always showing the DVD instead of TV channels? If that is the case, you need to change the TV input from what the DVD player is using. (for example component or Video 1, or HDMI 1 to whatever the TV is using for television provider's input. (for example HDMI 1 or HDMI 2 or component, or video 1, or video 2.) Usually the remote will have a button that says "input". If you push it, it will scroll through the various inputs. You may need to wait a few seconds between each choice for the change to happen.)
You can look at the cable from your DVD player to the TV and see if the inputs on the TV are labeled, and also look at the cable into the TV from the television provider (comcast, dishnetwork, or TV antenna) to see what input that is as well.
Dec 20, 2011 | Televison & Video
Hello, I need to know which hdmi channel I should be on for my insignia tv to watch comcast cable. I accidently change the channel on my remote... Thanks
It all depends on which HDMI input the cable box is connected to on the back of the TV....
They are usually labeled on the back...
Jun 09, 2011 | Televison & Video
The sound does not come on when first turned on. I have to turn the unit off-on several times before the sound works. I utilize compast for tv access.
Try using a different input. For example, if you are using an hdmi input, try using a component input instead (Its still HD) A sure way to test this is as such. Remove all cables from the Comcast box to the tv. Now, run your coax from comcast into the back of the comcast box. It will say something like "In from antenna" or "cable in." Now run a regular coax cable out of the box, into your tv. This will be labeled as "out to tv or vcr." Now put your tv on channel 4. If the sound is ok, then you know its a problem with your input on your tv. If you still have the issue, it is probably the Settop Box from Comcast. Please note, this is just to test the tv. This cable will not support HD television feeds. Hope this helps.
Jan 07, 2011 | Vizio Televison & Video
I have a Sony Trinaton XBR about 6 years old. Works great. Have Comcast cable and they recently installed a new cable box. Now I get all cable channels on "Video 6 - DVD" rather than "Video 7 -Cable Box"....
I was awaiting your response in chat session but could not get any thing.
Please hook cable box in Video input-7 instead of Video input-6 in TV and select Video input-7 with remote on TV.
Regarding continues on-screen display of video-6, press Display button on TV remote once, on-screen display will disappear.
Thanks.
Jul 12, 2009 | Sony Televison & Video
Comcast Remote Doesnt Change Inputs....
Try using the Panasonic codes 0250 or 0051
Jan 30, 2009 | Philips DVR-1
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Philips 32PFL3403D/27 32 in. LCD TV Logo
183 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
