Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
Linksys Router Issue
Linksys VOIP Broadband Router Phone #1 and #2 indicator lights will not stop blinking. No phone dial tone. I restarted the router and modem with no results.
My VOIP Adapter is lock I can't reach the web page
Posted on Jan 10, 2009
When I try and install my E1000 linksys router it causes the phone line (dial tone) to disappear. Also it doesn't have PPPOA as a protocol option. Also the linksys setup software says that it is n
Don't you require an RJ-11 for a phone line, cause I don't see one on this model? In any case, the ATM protocol should be handled by the ISP modem, and the router should just pick up the established network over Ethernet.
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done. Some models come with a setup disc, but not absolutely required.
http://homedownloads.cisco.com/downloads/userguide/E1000_V10_UG_USA_NC-WEB,0.pdf
Nov 22, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Tip
How to reset your VOIP modem
If you are having trouble connecting to the internet, please try these steps.<br /><br />1.Unplug the power to your modem. This is the box from your cable or DSL provider. <br /><br />2.Unplug the power to your VOIP phone adapter. If you don't have one skip this step. <br /><br />3.Unplug the power to your router. Wait 45 seconds, then Plug in your modem and wait for lights to stabilize on a specific pattern. (Usually takes about 1 minute) <br /><br />4.Plug in your VOIP phone adapter (if you have VOIP service) and wait until you have a dial tone on your phone again. If you don't have VOIP or know what VIOP is, skip this step.<br /><br />5.Plug in your VOIP phone adapter (if you have VOIP service) and wait until you have a dial tone on your phone again. If you don't have VOIP or know what VIOP is, skip this step. <br /><br />You may need to restart your computer for this to work :)<br />
on Mar 16, 2011 | Computers & Internet
Windows cannot find any networks on a HP530 Laptop, the wireless works only when manually connected
Your router is likely configured to not "Broadcast" its SSID name. You need to reconfigure the router to broadcast the SSID.
Mar 15, 2011 | Computers & Internet
Hi..i have a linksys voip 2pt adapter. My phone set keeps on going silent (i hear no tone). I tried going to the config menu but thewebpage never opens and it keeps on prompting me for user and pass (which...
If you are losing audio during a call, there is almost certainly a configuration issue. You are going to have to access the web GUI and correct the incorrect settings. If you plug an analog phone into one of the ports and dial ****, you will hear "configuration menu". Enter 73738#. It will tell you to enter 1 to confirm. Press 1. The unit will restart and you will be able to access the web utility using the default login/password. Do this only if you know what your settings need to be and you are capable of provisioning the device. This procedure will return the device to its factory default configuration. This will work assuming you have an unlocked voip adapter. If yours is locked by a service provider, there is a good chance you will not be able to default the adapter using this method.
May 28, 2010 | Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE...
Lynksys 54g no dial tone
Solid power light indicates that the router is still good. You need to reconfigure the router since you had a new modem.
May 25, 2010 | Linksys WRH54G Wireless Router
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
No dial tone on headset 2
If you have a regular phone, then connect it directly to the Vonage phone router. Be sure and connect to the correct port on the router (mine has 2 ports, and I use both, but a single line subscriber would only hook to Line 1).
See if you get a dial tone with the standard phone hooked up (we are testing that the Vonage is good.first, then we'll deal with the Uniden phone.). If not, what do the light's indicate on the Vonage router? Have you subscribed to Vonage? Do you have a cable between your router and the Vonage router?
Reply back back what you find and I can help you more.
Jan 23, 2009 | Uniden 5.8GHz Cordless Phone
Linksys Wireless-G Broadband Router
If the power light on the router is Blinking very Fast .
Then Reset the router fro 30 sec and then leave the power cable unplug for 1 min .
Then plug the power plug back in and then check ............if the power light stop light stop blinking then the router can be reused or else the router has gone bad
Mar 09, 2008 | Linksys Wireless-G Broadband Router
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
396 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
