Question about HP Compaq Presario V6000T Notebook
How do I get keys back on my Compaq V6000?
The v and CTRL key have fallen off. I can get the hinges or whatever those plastic white parts are back on the key but cannot get the keys back on the keyboard! How do I do that or am I going to need to order replacement keys? Thanks!
  • 116 Answers
You will need to replace them
Posted on Jan 09, 2009
Keys have fallen off my hp laptop
If keys have fallen of your hp laptop, you should be able to reattach them as long as there are no broken parts like hinge clips, or the back of the key cap, if there are broken, stop right there, don't do anything else as they will not go on, places like www.replacementlaptopkeys.com have a variety of hp laptop keys, and also installation guide, you may want to contact them for your laptop.
Jun 15, 2012 | HP Computers & Internet
My key has fallen off my acer aspire 7551g, is there a trick to getting it back on as i have all the peices?
If the plastic hinges are still in place on the keyboard then place the key on the keyboard and align it with the adjacent keys and press down on the key until it clicks and locks in place.
Apr 23, 2011 | Computers & Internet
I got problem with key pad of *,5,C, and center joystick button on my sony ericsson k770i...can u help me on how to solve the problem..?? tqvm...
emove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film. After the protective film is removed it's really hard to attach it back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
These separators secured on the back of the keyboard.
Plastic pins are melted on the back of the keyboard and retain separators in place.Push all plastic pins though wholes on the keyboard.Start removing the separator.The plastic separator has been removed.
Now you'll have to remove all key caps.
Before you start removing key caps, make a picture or xerocopy of the keyboard so you know the order in which keys are attached to the keyboard.In order to remove the key cap carefully lift it up with your fingers.Remove the key cap so the hinge underneath stays connected to the keyboard.
Some big keys have a different design.
In addition to the hinge, some big keys (Back space or Space bar for example) might have an additional support bracket.Remove the key cap with the support bracket. As you see, the key hinge stays connected to the keyboard.Some laptop keyboards might have blank covers on the left and right sides from the up arrow key.Lift up and remove the blank cover.All keyboard key caps and plastic separators have been removed.Now you can start removing key hinges - key lifting mechanisms.Carefully separate the key hinge from the keyboard.
Each key hinge has two parts - external and internal pieces.
When you remove the hinge, try to keep these parts connected to each other the same way they are connected on the keyboard.If the external and internal pieces got separated, you can assemble them together.If you following this guide to repair the keyboard, I would recommend to keep all hinges in the right order.
The keyboard has two sheets laying one on the top of another.
Remove the sheet with silicone (or rubber) nipples.Remove the second sheet with traces.Both sheets have been separated from the keyboard base.The sheet with traces has two layers and all traces are running between these layers.In order to access and repair traces you'll have to separate to layers from each other.The keyboard has been disassemble.
As you see it's not easy to disassemble a laptop keyboard and even harder to put it back together.
Is it worth repairing? Probably not. These days you can find a new laptop keyboard very cheap.
Oct 17, 2010 | Computers & Internet
How can i repaire my kerboard of aser 5920
Remove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film. After the protective film is removed it's really hard to attach it back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
Oct 17, 2010 | Acer Computers & Internet
Need to replace broken key on keybord. plastic appartus on key underside broke
Oct 17, 2010 | HP Pavilion ZD7140US Notebook
Some keys popped off...we have all the parts just dont know how to put then back
There should be two white pieces that hinge together. Put the togeter, then attach them to the key. They can only go in one direction, but you can put them upside down. On the white piece the hinges inside the other, the part that clips is going to be flush on one side, that is the side that clips to the key. One attached to the key, spread the away from the key as far as possible. One computer, you will see that it has two clips on either side for the key, one side will be l-shaped. With the hinges fully extended, tilt the key toward you and slide the white piece into the l clips on the board. Press down firmly and you should hear/feel the other to clips attach. It might take a few tries, I usually use my pocket knife to hold the hinges extended while I slip the first hinge in the clips.
Jan 26, 2010 | Dell Inspiron 1501 Notebook
Key won't come back up on Roland digital piano
Roland FP is a nice keyboard but has a known problem on cracking key weights. There is a counter weight under each key to push the key upward. There are two sizes of weight beams, longer one for white keys and shorter one for black keys. Roland did not make the original weight beams strong enough to last. They will crack and eventually break. When it happens, the key will stay down. Fortunately, they can be easily replaced.
Roland FP-8 has 4 black screws at the bottom on each side end. Remove the screws, flip the ends up and expose the interior. Near the hinge of the problematic key, carefully ply open the hinge tabs and remove the key from the hinge. You will find a weight beam under the key. Remove and inspect the weight. There should be a metal wrapped in a plastic beam. If the metal part is missing, find the missing part and replace with a new beam. You can order weight beams from Roland. It costs about $10 each plus shipping. Put everything back in the reversed order.
Oct 01, 2009 | Music
My CTRL and v keys fell off of the keyboard and I can't get them back on. I can get the white plastic things back on the keys but not the keys onto the laptop. I have a Compaq V6000.
princessvero,
I will try my best to help you here, but u need a proper instruction on my to work around with the key, here's a link to show to how to assemble the key back to your keyboard.
Key assemble
Don't forget to rank my solution... Thanks/
Jan 09, 2009 | HP Compaq Presario V6000T Notebook
Laptop keys
On a presario the keys are hinged with a small metal hinge at the top that fits into two plastic clips and lets the key sit over the membrane of the keyboard. If the plastic clips have snapped it will involve the fitting of a new keyboard which isnt a user serviceable thing.
If it's out of warranty (HP now own Compaq, so it's them you'll need to talk to, but they will tell you the warranty status from the serial number of the machine) you might consider a rubber "roll up keyboard" along the lines of http://www.iwantoneofthose.com/bendi-light-up-keyboard/index.html - these are rubber folding keyboards that can be transported easily in your laptop bag but are still full size.
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Key popped out
no do not glue anything this will couse more problems just try to pop them back in if totally broken then you will need new keys
Nov 03, 2007 | Dell Inspiron 6000 Notebook
HP Compaq Presario V6000T Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
