Question about Onkyo Audio Players & Recorders
L or R Channel cuttint out
I have two Onkyo M-1501 Amplifers that have the same problem. After they are running for a bit one of the channels either shuts off, or is on a really low volume level.
If I cycle the power, then I can hear it again, but after a bit, one of the channels shuts off.
Any help would be appreciated
  • gholt Jan 09, 2009
    Would the short be in the amp?
    I never have this problem when I hook it to other decks. I'm just wondering if a transistor has blown out because of age, etc that would cause this as well.
    In the past, I had 2 or three speakers hooked up to the amp. So, I think it was running at 2 ohms with 3 speakers rated at 8 ohms. (I did this before I knew it would cause problems.) If this helps anything.
    Additionally, the only time this seems to happen is when a left and right channel are running, not just one channel, but both speakers were hooked up at the time.
    I will try it tonight and see what happens.
    Scholar:
  • 73 Answers
You have a shorted speaker, crossed speaker wires Or a blown speaker. The amp is reacting to the short.
Start with one speaker by itself, unplug the rest. Check the polarity. Run it on the channel that cuts out. can you replicate it? Check the connections on the amp, and see if they are really close to touching.
Absolutely if it happens on both amps, unless you bought both B stock or Remanufacturerd and they have the same problem. This is rare
Hope that helps you!
Charles
Posted on Jan 09, 2009
  • charles durando Jan 09, 2009
    I would say it were the amp if it were not exactly happening on two different identical amps.
    there is the possibility that one of the sources is causeing the problem, you could also try changing the RCA cables to the sources.
Onkyo 545 one channel don't work
Use headphones or Computer Speakers
and plug in to your headphones jack.
If the audio is present on both channel , check your speaker system
or the jack circuits.
If symptoms are the same, follow the troubleshooting on the link
above.
Oct 09, 2012 | Onkyo TX-SV545 Receiver
Center channel stoped working on onkyo Dr-S2.2
Have you re-run the speaker definition and level steps? I can't find the manual. Perhaps you could flip a few pages in the Troubleshooting Section.
Mar 19, 2010 | Onkyo LS-V955 System
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
Can you tell the wattage of the onkyo tx 905 not the home theatre model stero only
140 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven from 20 Hz to 20 kHz, with a
maximum total harmonic distortion of 0.05% (FTC)
170 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven at 1 kHz, with a maximum total
harmonic distortion of 0.7% (FTC)
180 watts minimum continuous power per channel, 6 ohm
harmonic distortion of 0.1% (FTC)
Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
One channel of the amplifier seems to cut out
I see now how it could have happened to both amps. Yes, this triple speaker combo will cause this problem.
Next time if you want to run speakers like that, instead of parallelling them, series them.
That way the load is balanced between the speakers.
Here is a great primer, dont worry about the calculations and mumbo jumbo, the pictures should tell you what you need to know to get it done.
http://www.termpro.com/articles/spkrz.html
also when you talk about bridge, that is usually done on the amp rather than the speaker. For example I could have a 4 channel amp, and bridge it to 2 by combining the channels, BEWARE not just parrallell again, there will be a specific order for each different amp and it will be marked.
You can also bridge a two channel amp to make one Single channel amp with almost double the power, but again only to one channel, now that its bridged.
Hope that helps once again. I'm going to look up that amp, if you want more specifics.
Charles
Jan 09, 2009 | Onkyo Audio Players & Recorders
7.1 channel onkyo home theater -- no sound out of subwoofer
You might try different listening modes; Some modes (Direct, DTS, Dolby - though I'm not sure which, offhand) require a seperate LFE track for sound to be output by the subwoofer.
Nov 25, 2008 | Onkyo 630-Watt 7.1 Channel Home Theater...
GETTINF OVER HEAT
Onkyos are notorious for running a bit warm - though if yours is excessively warm, double-check the impedance of, and wiring -to- your drivers.
Nov 13, 2008 | Onkyo 630-Watt 7.1 Channel Home Theater...
Car amplifers,,,,kicker amp's RCA jacks!
You could do a couple things if your head unit has all three outputs, then take them and hook them into the inputs. If you have just the front and the rear outputs, hook those to the inputs front and rear. Then hook the output of the 4 channel to the input of the mono block. I hope this helped
-Andrew Hawkins
Mar 28, 2008 | Audio Players & Recorders
Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Sep 02, 2007 | Kenwood VR-305
169 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
