Question about Dell 924 All-in-One InkJet Printer
Size of print changed to very small permanently..automatically
I have tried to change the print size without success..
  • Anonymous Feb 06, 2009
    How to enlarge print size when using Dell Printer ?
  • ebrooks1 Mar 28, 2009
    ALL SUGGESTIONS ALREADY TRIED PRIOR TO SOLICITING HELP>>>
    Problem Solver:
  • 3 Answers
Check your printing preferences, make sure your page layout is set to standard, 8.5x11, and your checkbox for 'scale to fit' is checked. use of a image editing software like photoshop is very useful when trying to change sizes of orginal images or pictures.
Posted on Jan 09, 2009
How to change print size
Assuming you're referring to the print size of the fonts - letters ..... or the size of the printed page ...
If you're printing from your computer, you'll need to change the size of the font (to a larger font size) on your document before you print, or adjust the print Properties ... to fit to page, or magnify the size of a small document ...
If you're printing a pdf file, you can specify the size of the document using the enlarge (%) before you send it to the printer
Jan 15, 2014 | Epson WorkForce WF-2530 All-in-One...
Photos are not printing to correct size
May i know the model # of the printer.
You can also try this. When you click on Print button and the window pop up - Click on printing preference and check the Size of paper in the Advance/feature tab.
If you find any other size you dont want, set it to the correct size you want it to print.
IF you want to make these changes permanently, Click on START Button and click on Control panel and open Printers folder - Highlight the printer icon and right click on it and click on printing preferences and change the paper type.
Regards,
Suhail
May 20, 2012 | Epson Office Equipment & Supplies
Font size issue
Are you trying to print a two-line label?
If there are two lines of text, they are printed in size 1, regardeless the size you set.
Here is the procedure, described in the manual you can download from here:
http://welcome.solutions.brother.com/BSC/public/files/dlf/docp000113/pt1180ug01usen.pdf
Note:
• If there are two lines of text, they are printed with the SIZE1 setting applied,
regardless of the selected size setting.
• To quit the following procedure at any time without making any changes, press [BS/Clear] key.
1 Press [Function].
2 Press [<] and [>] until SIZE is displayed, and then press [Function] or [Backspace]. The current size setting appears in the display.
3 Press [<] and [>] and until the desired size setting is displayed.
4 Press [Function] (or [Backspace] ) to apply the selected size setting to the text.
Aug 06, 2009 | Brother P-Touch 1180 Label Printer
How do I increase font print size for a printing
you will need to increase the size from the program you are using generally if you go to edit font. the program should give you alternate sizes to change.
Feb 24, 2009 | HP Photosmart C7280 Printer
I have a c4200 hp Printer cc200-90006 i need to know how to get the printing larger.Can't read my bankstatements to small when I try to copy.
Make sure you have the proper drivers installed for the printer, then cut and paste the information into a word processor or similar that accomidates the desired print format.
Finally, change the text size and print.
The issue is not with the printer, but the program you are using to facilitate the print job. If this is a web based program, look for a "Printer Friendly" print option on the site.
Alternately, you may have limited success in changing the text size under "View" in your browser, and try printing with the larger text size selected, and in use. If truncating occurs in the printing, then you will have to cut and paste the text into a manageable format, like a Word Processor program.
Nov 19, 2008 | HP Office Equipment & Supplies
Changing Mode?
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Jun 23, 2008 | Minolta bizhub 200 All-In-One Printer
Small print size
ok...try a test page first, with printer off the computer completely
and..check for newest printer drivers here
Mar 07, 2008 | HP PSC 2210 All-In-One InkJet Printer
CHR SIZE AUTO?
Press the Return button and the machine will automatically print the size the tape will allow! :) Title:
What does the error message "CHR SIZE AUTO?" mean? Description:This message appears when the selected character size is too large for the width of the tape cassette installed.
You have the following options:
  • Press the "Print" or "Return" key to allow the P-touch machine to automatically select the maximum character size that fits the tape width.
  • Press the "BS" key to clear the message, and then install a wider tape cassette.
  • Press the "BS" key to clear the message, and then select a smaller character size by following these steps:
    1. While holding the "Code" key, press the "Size" key. The display will show the current character size.
    2. Keep the "Code" key held, and press the "Size" key until the desired size is displayed.
      If you select "AUTO", the P-touch machine will automatically adjust the character size to the largest possible size.
    3. Release the "Code" to apply the setting.
If you have the correct size tape installed and still get the error message, please try removing the cassette from the machine and reinstalling it. Also, check that the tape cassette is seated firmly in the compartment.
Note
    The following table shows the maximum character size that can be used with each tape width.
    Tape Width Maximum Character Size 1/4" (6 mm) 12 points 3/8" (9 mm) 18 points 1/2" (12 mm) 24 points 3/4" (18 mm) 42 points
Related Models PT-1900
Feb 17, 2008 | Brother P-Touch 1900 Label Printer
Paper size repeatedly returns to "Letter" when I want A4size
go to control panel and choose printer and fax option, right click and select printing preferences. select page setup tab, adjust the paper size to your wanted dimension, then finally click apply and ok. this changes is permanent.
Dec 19, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Dell 924 All-in-One InkJet Printer Logo
73 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
