Question about Frigidaire FEF336BC Electric Kitchen Range
Is their a reset button on a frigidaire elctric range model ES300
There is power but the burners and oven will not turn on.
  • Anonymous Feb 17, 2009
    I'm looking for a reset switch of some kind. Can't find my owner's manual.
  • Kaylyn Myers
    Kaylyn Myers Feb 22, 2015
    Go to this website, they are really helpful! http://www.repairclinic.com/RepairHelp/H...
Clock, timer, temp gauges for oven shorted out, is there a reset button?
Posted on Mar 22, 2011
Why won't the oven or the burners heat up on our brand new model CFEF3018LB range
Thank you for your inquiry, friend!
It could be a possible issue with the control panel or burner switches within the Frigidaire range. I would recommend performing a reset on your appliance which you can do by flipping the household circuit breaker off for ten minutes. It could also be an issue with your range not receiving sufficient power. You may want to seek assistance from a professional for proper repairs. -Matt
Oct 16, 2014 | Frigidaire Kitchen Ranges
The front left range element on our frigidaire electric range es300 does not appear to be heating at all. The unit's "Element On" light turns on, but the element itself does not come on. Eve
Good afternoon friend, thanks for your inquiry!
Based off the information you have provided me regarding your Frigidaire range element not working I am able to identify some possibilities with your range. It could be an issue with your burner switch or burner element. It would be best to have a professional come out and properly diagnosis your appliance to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Oct 05, 2014 | Frigidaire FEF368GM Free-Standing 30-Inch...
Frigidaire oven and broiler stopped working but clock andtop burners work
Hello Friend, this is Z. I am happy to assist you!
I see that both the clock and burners of your Frigidaire range are working but your oven does not bake or broil. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better address the issue at hand.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you!
Sep 06, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire stove
Hello Randy, thank you for your post!
I see your appliance stopped working after using the oven and all the burners. It sounds like the panel could have been shorted out or overheated. I would recommend a reset which can be done by disconnecting power from your appliance, you can do that by flipping the household circuit breaker off for roughly ten minutes. I hope this is helpful. -Matt
Sep 01, 2014 | Frigidaire FGEF3032MF Gallery 30"...
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
Jun 08, 2011 | Frigidaire FGF368GM Kitchen Range
My burners work on the stove but the clock, and over buttons will not come on, so I'm unable to turn on the oven. I have a Frigidaire model FEF366EMC
Check for a blown thermal fuse protector. Located on the back wall of the oven behind a sheet metal cover. Disconnect power and you can ohm it out.
Jun 27, 2010 | Frigidaire FEF366 Electric Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven doesn't heat
Its are a wall oven or range???
Model number please
May 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire es300
you could have a power problem.. the stove will still work with half the power..like the burners on top will work. if thats not it. the wirers could be crossed or you may have a thermal cutout thats bad. but when the tco is bad broil and bake should not be working.. hope this helps
Feb 27, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire FEF336BC Electric Kitchen Range Logo
2,684 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
