Question about Onkyo Audio Players & Recorders
One channel of the amplifier seems to cut out
I have two onkyou M-1501 amps that have the same problem. When I run them with my home theatre to get more watts, it seems that one of the channels (L or R) cuts out so that it can barely be heard.
In the past I ran 2 or 3 speakers to the same channel to get it to bridge, this may have caused the problem.
    Scholar:
  • 73 Answers
I see now how it could have happened to both amps. Yes, this triple speaker combo will cause this problem.
Next time if you want to run speakers like that, instead of parallelling them, series them.
That way the load is balanced between the speakers.
Here is a great primer, dont worry about the calculations and mumbo jumbo, the pictures should tell you what you need to know to get it done.
http://www.termpro.com/articles/spkrz.html
also when you talk about bridge, that is usually done on the amp rather than the speaker. For example I could have a 4 channel amp, and bridge it to 2 by combining the channels, BEWARE not just parrallell again, there will be a specific order for each different amp and it will be marked.
You can also bridge a two channel amp to make one Single channel amp with almost double the power, but again only to one channel, now that its bridged.
Hope that helps once again. I'm going to look up that amp, if you want more specifics.
Charles
Posted on Jan 09, 2009
Conversion to home theatre
You will need a separate stereo amplifier for the 901's to accommodate the need for the Active EQ. There is no way to separate your receiver's front L&R channel preamplifiers from their amplifiers.
I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's. If your receiver requires a powered Subwoofer so you would need another amplifier channel for that, too. Therefore, you might look around for a powerful 3- or 4-channel amplifier so you could drive the Sub, too.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Not what you might want to hear but 901's have special requirements. I've had mine for 25 years and have no regrets.
A separate subwoofer channel on the amp could be used. Just run a single RCA channel from Sub OUT to one available channel IN on the amp and attach the subwoofer to it. Two would work, also. That's what I do. You could use a 1-2 RCA splitter to feed two available channels on a 4-channel amp. The iterations are many. Have fun.
Jan 19, 2009 | Bose 901 VI Main / Stereo Speaker
L or R Channel cuttint out
You have a shorted speaker, crossed speaker wires Or a blown speaker. The amp is reacting to the short.
Start with one speaker by itself, unplug the rest. Check the polarity. Run it on the channel that cuts out. can you replicate it? Check the connections on the amp, and see if they are really close to touching.
Absolutely if it happens on both amps, unless you bought both B stock or Remanufacturerd and they have the same problem. This is rare
Hope that helps you!
Charles
Jan 09, 2009 | Onkyo Audio Players & Recorders
Connecting an audio/video transmitter to Yamaha HTR 5830 Amp
If you want to get sound out to speakers use the KEFF WIRELESS SYSTEM as this will not break up or cut out.
Hope this helps.
CABLE GUY.
Dec 29, 2008 | Audio Players & Recorders
Can i connect JVC SXXSW6000 home theatre to my pc...if so how?
You need a receiver. A surround sound receiver is a 5-channel amplifier with a line-level subwoofer out. These are available at electronics stores. Receivers usually have digital inputs like optical and coaxial that you can use with the S/PDIF output of your PC.
Nov 06, 2008 | JVC SXXSW6000 Speaker
Home theatre amplifier right speaker not working even with any other speakers.
I have 20 year exp. with Krell. Contact me directly.
Steven Leckrone
The Service Department
203-331-0671
sleckrone@snet.net
Oct 15, 2008 | Krell Home Theater Standard 7.1...
Audio problem with my home L.G theatre
please bring lubricat contact cleaner and apply the spray in the socket where you put your mic and insert mic jack in and out many times.
Jul 04, 2008 | Audio Players & Recorders
Connecting amplifier
use pre amp with 10 inputs and connect its output to aux in----in mixer.
May 13, 2008 | Audio Players & Recorders
Left Front Channel Goes in and Out
left channel there is a problem use a tester to locate the bad transistor
Sep 16, 2007 | Alpine MRV-F357 Car Audio Amplifier
Channel cuts out
I suggest you switch your speakers and test again , if the same happens , ship it it can only be an output problem >>>>Good luck
Jan 30, 2007 | Classe CAV-500 5-Channel Amplifier
182 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
