Question about GE WBSR3140D Top Load Washer
GE Washer wbsr3140d5ww water problem
I have a problem with my washer For some reason when I try to start the washer and I have it set to cold it does not work if I put it to hot then its fine The cold water does work though because if I change the washer to a later cycle cold water comes out just fine. So it almost seems like its the timer knob any ideas? Thanks
  • Anonymous Feb 10, 2009
    The washer will not work during the agitation mode. Water will fill but the washer does not agitate. It does however spin. The timer is now loader than normal. any ideas/solutions.
  • 750 Answers
Hello Chad
Welcome
Sounds like the cold water knob or switch is not switching and may be faulty.
any ideas?
Thanks
Please remember to leave a rating
Posted on Oct 04, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Cold Pulses when set to HOT only
if you want only hot water, shut off the cold.. its only really used during the rinse anyway..
Feb 02, 2014 | GE Spacemaker Washer and Dryer Electric...
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
Water keeps running in i have got to cut water off to spin dry
There is an electrically controlled water valve for both hot and cold water on the back of the washer, do both settings not shut off? if it is just the cold pull the washer out and replace the cold water solenoid water valve.
Mar 10, 2011 | GE WSXH208A Front Load Washer
Can I use only cold water with my GE front load washer
Just used the cold water and plugged the hit water tube. It worked.
Mar 18, 2009 | GE Profile WPXH214F
No hot water into washer
In your problem you describe that you are getting hot water are you getting cold water too?. Make sure on the water valves are on the full open setting to eliminate a water pressure diffrence and any other valves connected to those water lines. If that checks out check for clogs in the hoses and filters that could be backed up. If that dosent fix the problem then its in the washer either the hot/ cold regulators or the timer.
This is for GE WBSR3140DW Top Load Washer
Heres a link to help to find the correct parts.
http://www.partstore.com/Model/General+Electric/General+Electric/WBSR3140DW.aspx
Hope this info helps to anyone who reads it.
Feb 25, 2009 | GE WBSR3140DW Top Load Washer
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
GE washer
if you are only getting hot water on warm setting possible bad inlet valve cold side ck wiring first just to be sure wire to cold side not loose
Jun 08, 2008 | GE WHRE5260E Top Load Washer
Ge profile whsb8000bocc
Washer is most likely trying to fill with cold rinse water and the inlet screen is blocked or the cold water solenoid is bad. If you set washer to wash cold only it will not fill or fill very slowly. When you set it to warm or hot you are getting almost all hot. Clean inlet screen or replace inlet water valve.
May 12, 2008 | GE Profile WPSR3120WWW
GE WBSR3140D Top Load Washer Logo
938 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
