Question about SanDisk Sansa e250 MP3 Player
Where do i find a replacement screen?The LCD, not the plastic...
I smashed my sansa between my car door and the car, the screen is cracked. Where can i get a replacement, or some1 to fix it?
  • 390 Answers
You should check on EBAY as there are people selling non functioning broken units cheap and usually in lots (multiple pieces).
Get the necessary replacement parts you need there and do a part swap on your unit.
Posted on Jan 17, 2009
I had a smashed screen on my Mac computer. I removed the lcd and removed the screen. There were a couple plastic sheets that I removed from the lcd by mistake. What order do the sheets have to go b
go to the website
they will have pictorial step by step instructions on how they teardown and LCD replacement goes. dude, I\'m an apple IT pro, even i snap a photo and use a manual at every step. I HOPE YOU GROUNDE AND USED A CRT DISCHARGER... good luck.
Dec 14, 2012 | Apple iMac G5 Desktop
How to fix a crack inside a LG LCD TV
The short answer is a cracked LCD is not worth repairing.
Here is a link to some more info, cover cost and whats involved.Broken Screen's Repair and Info Cracked, Broken, Smashed Bad LCD, Plasma and LED Panels
Jun 10, 2012 | LG 42LC2D 42 in. LCD HDTV
Logitech harmony one
  • Dear Sir:
    Turn off the power to your computer and unplug all cables connected to it. Remove the battery, if one is installed.
  • 2
    Locate the covered screws around the cracked screen. Remove the rubber or plastic covers, then unscrew the screws.
  • 3
    Gently remove the plastic frame around the cracked screen and set it aside. Disconnect any power cords or cables going into the LCD screen.
  • 4
    Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
  • 5
    Reconnect all internal cords to the screen. Screw in the frame and replace all the screw covers.
  • 6
    Reconnect the power supply and all external cables to the LCD screen and switch it on.
    sincerely. God bless you
    ernesto cuadra
    managua, nicaragua. c.a.
  • Feb 15, 2012 | Logitech Harmony One LCD Touchscreen...
    The plastic screen isn't broken, but when I turn it on, it appears as broken.
    if there are no visible marks or cracks on the plastic case itself then it sounds like the LCD screen behind the plastic protective screen is cracked or damaged (especially if its been dropped, or had a lot of pressure put on it e.g. left in a pocket when sitting down, heavy object on it), if its new i would consider taking it back with the receipt for a replacement.
    otherwise it will need someone with some repair skills to replace the screen.
    Aug 06, 2010 | SanDisk Sansa e250 MP3 Player
    Damaged LCD, Low battery LED on, wont comunicate with PC.
    Replace or Repair the display on the Sony K800i. If your k800i screen is cracked, this guide will help you. If your Sony K800i LCD is dead, then this video will show you how to disassemble and replace it. If your lcd screen on your k800i is smashed, then this post will help you fix it yourself for a very low cost.
    Replace LCD Screen on Sony K800i Display
    Feb 06, 2010 | Sony Ericsson K800i Cellular Phone
    52" LCD FULL HD TV screen is cracked doesnt give any picture
    Unfortunatly, no.. You will end up spending more on the repair then the cost of a new tv typically.
    Sep 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
    Iphone screen smashed, touch still works but white spots
    If hard resetting and restoring it doesn't work you have a broken LCD screen. There is an iphone repair guide website that shows you how to replace the screen yourself.
    Mar 18, 2009 | Apple iPhone Smartphone
    Cracked screen e280
    My best advice is to get a junk player from ebay or other source,one that has a good screen. There are only 4 screws that hold the screen on,once you remove the back. With a small phillips screwdriver and about 10 minutes you can replace the screen.
    Apr 25, 2008 | SanDisk Sansa E280 MP3 Player
    Screen Cracked
    Unfortunately you wont be able to fix the crack will have to get a new MP3 player...
    Hope that help you
    Please rate accordingly..
    Jan 29, 2008 | SanDisk Sansa e250 MP3 Player
    Sansa e250 cracked screen
    I've tried to get a replacement LCD for my SANSA, impossible so far.
    There are some PARTS/REPAIR SANSA's on ebay, but must of them with the same problem. There was also a working LCD, I just fail on bidding.
    If you can get a working LCD, the replacement is possible with a blower, directing heat to the specifyc connectors area, you can remove the broken one while the glue (some kind of silicon) is warm and flexible, you have to be careful when putting the new one, pins must be aligned, also you should do that whith both (broken and wkring) at the same time, so then you can use the glue still on the pins (golden connectors) area.
    I got to remove the broken one and noticed (with my fingers) that the silicon can be used again, but since I didn't use a blower some of the pins (connectors) where damaged. Only halve of the process is confirmed.
    Good luck, we'll wait 4 your results if you get a working LCD somewhere..
    Nov 30, 2006 | SanDisk Sansa e250 MP3 Player
    SanDisk Sansa e250 MP3 Player Logo
    59 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
