Question about Kenmore Washing Machines
Kenmore washer the washer fills up and then stops.it only drains thats it.model #4450290,serial#cd3312652,type111
  • 13 more comments
  • bratcarder Jan 09, 2009
    not sure of the year ,bought it off someone a couple years ago.i know it is a older one though.
    i tok the agitator off and the piece it sits on underneath does not move.it is also making some kind of funny noise.
    not sure what a coupler is ,exactly where under the washer is this ,and can this be fixed?how much would it cost?
    ok i thank u so much for your help . i will check and see if this is it.thanks again. gayle
    oh 1 more thing please .can i change this myself?
    thanks so much. gayle
  • bratcarder Jan 10, 2009
    do you have to take the motor out to replace this part?also would u happen to have a diagram on how to do this?thanks again
    thanks again gayle
  • MrCaesar May 11, 2010
    If you loosen the motor it should slide out of the way. No sorry I don't have a diagram on me
    yes it takes some elbow grease, sometimes you need 3 hands :)
    Should look like this they are about $20 if the black coupler is torn up its mostlikely the reason you have no agitation
    You're coupler under the washer is gone if you check underneath you should see its probably done in
    Is there any black crumbs underneath the washer?
    Does the agitator spin if you try to turn it by hand?
    What year is it?
  • 15,935 Answers
Check / Replace the timer and pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
The time between cycles ranges from 1 minute to 5 minutes. Model number LSR7010PQ0 Type111 This washer is about 8 years old. Owner uses once a week.
check your water supply to the machine especialy the cold. does it takes too long to fill?. if that is the case you may have a dirty or faulty water valve. also chech the screens in the fill hoses for dirt on both sides. the washer and the faucet.
Feb 19, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
When my washer spins, it sounds like somehting is loose. kenmore 80series , model#11020802990 type111
does it continue to spin and make noise when you open the lid?
could be the drive block.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Washer won't stop filling and go to next cycle automatically
if not running over ck to be sure drain is proper height and end of washer drain hose is not too tight in standpipe sound like siphoning after 1st wash and not filling to advance to rinse also be sure washer dring hose is not more than 6-8 in into standpipe
Aug 15, 2008 | Kenmore 24032\24036 Top Load Washer
My kenmore washer fills up but then just stops
it could be several things, something is lodged in pump, so the motor wont run, the motor is bad, or you have a bad transmission.
Start with the pump and see if it has sock or something stuck in it.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
83 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
