Question about E-Machines M2352 Notebook
M2352 Power issue
The pin that the power supply plugs into is loose.
Does anyone know of a quick fix for this?
  • 4 Answers
Normally, the positive and negative posts have been soldered nominally, and it works its way loose after a while. I've got 2 solutions, but both involve disassembly of the laptop in order to get the matoherboard out and access to the underside, where the solder joints are. You may order a new socket from Ebay if your timing is right, and it may be jut the issue described above, inadequate solder on the 2 posts.
What I found was the positive post with gaps around it. The negative was in better shape, but I resoldered both.
I had planned to remove the socket, and replace it with a 2-conductor piece of lamp cord, and an M size DC inline socket, available for $5 at Radio Shack. If the inline ever crapped out, it could be replaced, and the motherboard would not have the stresses of the adapter being plugged in, possibly at bad angles. I still have the M DC socket, if the solder job fails.
Posted on Mar 20, 2009
  • celso337 May 25, 2011
    Hola, la capacidad total de este modelo M2352 de eMachines y similares es de 1024Mb, NO de 1280Mb, esto es, tiene dos placas de 256Mb originalmente, una interna y una externa, juntas suman 512Mb, eMachines dice que acepta 1GB y en la web dicen que acepta 1GB, nadie define la capacidad completa, todos venden RAM de 512 y de 1GB, solo cambiando la RAM externa, si se cambia la externa por una de 512Mb mas la interna serán 768Mb totales sin problemas de reconocimiento, se puede cambiar la interna y la externa por un par de RAM de 512Mb sumando 1024Mb o 1GB como dicen sin problemas de reconocimiento, es la mejor alternativa que he deducido, por la falta de información y confusión que genera esa misma informacion. si te pasas de 1024Mb totales, siempre va haber problemas de reconocimiento sin importar la marca o capacidad de la RAM a instalar, NO acepta winVista ni Win7, sólo trabaja con winXPHome Edition, el cable y conector de corriente electrica que alimentan a la M2352 son de mala calidad, con el uso diario y muchas horas se sobre calientan hasta el punto de comenzar a derretirse, todas las partes plásticas se dañan y empieza a hacer corto, humea y sacan chispas, por estar en contacto el polo positivo y negativo, esto puede dañar la M2352, la solución es abrir y tener acceso a la placa madre, quitar el material dañado y soldar directamente los cables de alimentación y que toleren un voltaje mas alto de 18volts, si es menor se quema el cable y nuevamente hace corto, es una solución radical, antiestética pero funciona muy bien.
  • E-Machines Master
  • 32,281 Answers
There is no quick fix other than tapping or glueing it into a position that works. This is not a permanent fix and will fail again sometime.
The laptop power connector is either loose or faulty, the laptop needs to be dismantled to access the plug to resolder it (if loose) or replaced if faulty.
Posted on Jan 10, 2009
PC Power Issue
If it only comes on when you move the cables but not if you don't then one of the cable connections (pins) are loose or internally broken. Unplug it and check each cable/pin for any loose connections, bent pins etc.
Nov 09, 2014 | CORSAIR CX Series Modular CX750M 750W ATX...
Power supply issue for pioneer x-smc3-k
Please visit the Pioneer website where you can buy a new power supply. As to what pin is positive or negative, look on the back of the case where the power supply plugs in. It's imprinted right on the case. For more information, or should you have any further questions, please visit my website at audioserviceclinic.com. Thank you.
Apr 27, 2013 | Pioneer X-smc3-s Music Tap Airplay Music...
1999 harley davidson electra glide classic INT start.
The igntion switch is the point that both connect to.
Feb 07, 2012 | Motorcycles
Inside I smell something burning and my power port is loose.
Your Notebook PC needs a new power supply or at least a new power port, or it may self-destruct really soon (like tonight). Unplug your PC and quickly backup your important data to a flash drive.
I wouldn't plug anything into the power port until it gets service, and unplug it overnight (or there could be a fire).
The owners' manual doesn't describe power supply replacement:
http://support.gateway.com/emachines/Mobile/eMachines/M2350/M2xxx_030804.pdf
Here's a picture of the bottom of the system:
http://support.gateway.com/emachines/Mobile/eMachines/M6810/M6810bv.shtml
Jan 17, 2011 | E-Machines M2352 Notebook
Does anyone know which connector to plug into on power supply
Double check all the connections from the AC line and from the power supply to the other circuit boards. The connectors you are mentioning are identical as per the picture below.
If you need a new power supply, you can find one from this link.
Dec 04, 2009 | Protron PLTV3250 32 in. LCD Television
My eMachines M2352 laptop screen turns off from time to time and then I can no longer use the computer, the internet stops working, the keyboard, the speakers stop playing audio, almost as if the computer...
Sounds like its entering hibernation or sleep. Check your power settings in control panel. If that doesn't correct it look into administrative tools and check the event logs for any errors that will lead you to the correct fix
Aug 30, 2009 | E-Machines M2352 Notebook
My r3000 has a tempermental power supply. it
whatabout the lead that plugs into the laptop ? does the plug in the laptop move easily, with the lead in, Sounds like the actual plug in the laptop is breaking away, the solder around the connector. Sadly to fix that you will have to get it repaired for about £50 to £70, maybe more ?? please make sure the lead from power supply is not loose or a bad fitting.
Jun 14, 2009 | Compaq Presario R3000 Notebook
Won't turn on with new power supply
Sounds like the switch is out to me or it is mis connected to the motherboard
May 02, 2009 | HP Media Center M370N (DM163A#ABA) PC...
Just Bought The Mach 4 tried to test it with current power supply
Hi, one quick thing you can check is to see if the cable running from the power switch is plugged onto the right pins on the motherboard, it will most likerly say (pwr btn) next to the pins or something like that, it may also need to be a certain way round.Let me know what the outcome is if no good we can try something else. hope this has helped. Thanks
Onlinepc-Fix
lee
Mar 18, 2008 | Pine Technology Mach 4 KT400ANB...
Power supply issues
Have you checked the AC power pin (where the AC cord plugs in)?
Chances are that the pin has come loose from tugging and pulling on it. When this happens the battery charging is intermittent at best. The parts to fix this problem are usually under $10 but the labor if you take it in is gonna run $100-$200. You can repair it yourself if you're comfortable working with electronic components. Not that tough. WHen you get it fixed, invest in a Cable Retention device to keep it from happening again.
Here's a short video that talks about it. . .
Feb 26, 2008 | Dell Inspiron 710m Notebook
Open Questions:
My E-machines laptop's internet connection is slow via Wi-Fi. My e-machines laptop does not connect to the internet at full speed when on the Wi-Fi network however on Ethernet it will connect at its full speed. Now I know Wi-Fi does tend to be slower than direct cable connection however I do have other laptops in the house and they all produce the following results on broadband speed tests on the internet: E-Machines laptop: 4.7 Mbps (seems to cap out at this speed) Other laptop(s): 5.7 Mbps This only happens in my home network because if I take my E-machines elsewhere to other networks it can reach higher speeds. So that rules out that something is wrong with my Wi-Fi adapter built into it. I currently have At&t U-Verse service with a 6 Mbps internet service with a 2Wire Router/Modem Gateway. I had a technician from At&t come out and he checked the router and said it was fine nothing wrong with it. He checked the internet line and indeed I am receiving the full internet speed. His very own laptop connected to the Wi-Fi and received 5.7 Mbps just fine. The interesting thing is that previously when I had At&t FastAccess Dsl with the 6.0 Mbps service as well, I would receive via Wi-Fi on this very laptop 5.2 Mbps however, in that case that is what every other device would receive as well because the internet speed coming into the home was about 5.6 Mbps max because of the Dsl tech. So all in all, what could be going on with my computer that is causing it to max out a full Megabit lower than all the other devices connecting to the same network??? I am running Windows XP with all the updates, no issues with the computer such as Viruses or AdWare either. P.S. I've used both Speedtest.net and Speakeasy broadband tests on all the laptops tested (even the iPhone and iPod Touch).
Oct 03, 2009 | E-Machines M2352 Notebook
See all E-Machines M2352 Notebook Questions
E-Machines M2352 Notebook Logo
152 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
