SOURCE: R51 vartical line on display
Try reinstalling all over, format your notebook and freshly install again your OS and drivers. It sometimes happen when we tweak some drivers it saved into the registry, it can be happen that settings is still there in the registry even you uninstall the driver, cause it's still the same driver although it has a different version. Sounds intriguing...? BUt its true, coz' you just only update the firmware but with the same driver.
tnx
-micro
SOURCE: Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
SOURCE: Screen lines on MacBook.
Sounds like dropped pixels. My first guess is the computer has been dropped on its corner, with the pixel dropout radiating diagonally from the corner.
My saint bernard sat on my g3 lombard, and I have vertical pixel dropout because of it, from the top of the screen to the bottom.
And no, it is not normal for a macbook to have lines across the screen.
Linda h.
SOURCE: display shows pink color lines in white areas of the screen
Reinstall your VGA driver and i assume, it should be fixed if not you need to think about *********** board.
thanks
SOURCE: Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
