Question about Zefal Bicycle Duo 821 XLT Frame Pumps
Need rebuild kit for zefal plus bouble barrel floor pump
Do they offer rebuild kit ? Thanks.
Is it a good idea to rebuild your carb after rebuilding your motor
Most certainly it is. It should just go along with the rebuild regardless if it is ready or not.
Jun 05, 2016 | Cars & Trucks
My pw80 has a ceased motor. I took the head off and there is a lot of surface rust. How do I +go about sorting this outis it possible to get a rebuild kit or is it a write off??
Ebay has piston , ring and gasket kits for about $30. The barrel is cast iron, so if there is no lip a simple hone may do.
I f the barrel is pitted , you will need an oversize piston kit, and a machine shop to bore the barrel to a bigger size.
Jul 13, 2011 | Yamaha Apache RTR 180 Motorcycles
I have a 69 Ford F100, 1 barrel carburater, the choke needs to be wide open for it to run. When I switch gears, I need to close choke and open it back up when I shift-this is the only way it will run. If I...
You need to rebuild the carburetor. As it is a 1 barrel its relatively easy to rebuild if you can find a kit, but it is the original carb and difficult to find parts. You may also consider buying a Holley 2 barrel carb - it will bolt right on and give you more power, and they are much more common and easier to find rebuild kits and parts. It's possible you may need an adapter plate, depending on the configuration of your intake manifold, but that will be easy to find. You can either shop online or buy from your local auto parts store or high performance shop. That old 1 barrel has had its day and I'm sure it served you well,but I think I would upgrade to a newer carb myself.You may be able to clean it out using carb cleaner spray but it would be hard to clear out that clogged jet that is causing your trouble, and then you will likely tear the gasket when you take the top off that carb.
Nov 18, 2010 | 1981 Ford F 100
I have a Zefal HP frame pump. I'm trying to inflate a tire with a Presta valve. It just won't inflate. It doesn't latch onto the valve and seems to big for the valve body. Is there a diagram available...
Let's hope you didn't force it and snap the plastic point off.
Most Zefal pumps come with a reversible head that can adapt to either Presta or Schreader (like on cars). You unscrew the barrel at the working end of the valve, carefully tap out the rubber cylinder and the plastic internal piece behind it.
Insert the plastic piece in either of two ways. Pointy part Out (for Schrader) or just a round opening Out (for Presta). Rotate the rubber piece correspondingly to show the large opening for Schrader or the smaller opening for Presta and place it inside the valve over the plastic piece. Screw the knurled barrel on tightly.
Aug 12, 2010 | Zefal Bicycle HPX 3 Road Frame Pump
What size break line's will I need for a 1995 oldsmobile cutlass supreme..i think it has to be a certan center meter.. i need to do all the break line's thanks Jaymi
use 3/16 brake line, thats what i use and ive done a ton of those, your going to need a flare kit or bouble flare kit depending on what type you have, good luck.
Oct 20, 2009 | 1995 Oldsmobile Cutlass Supreme
My 1988 868 mercruiser needs the 2 barrel carburator rebuilt.is there an automotive rebuild kit available for this application and does it include an accelerator pump?Thank you for your valuable time...
hi yes the automotive kit is the same bar the main jet size a pump diaphram will be in the kit but if the pump is a piston type i dought there will be a piton they do wear a bit if it is worn out you could have a problem maybe a wreaker yard but put your jets in or you will lose top end and acceleration hope this helps merlin v12
Aug 23, 2009 | Boating
Only runs on prime.....9.9hp
Sounds like the diapraghm fuel pump needs rebuilding. Fairly cheap and simple procedure. Get a fuel pump kit from your local outboard dealer and follow exactly how the old one came apart.
You may also need to get a carby rebuild kit and do that too if it has been a while. Again pretty straight forward. Take photos of carby as you re pulling it apart.
Both these plus a new set of spark plugs and you should be good to go on the water.
Jul 12, 2009 | Bass Pro Boating
Bosch Breaker Hammer Service Kit Install
The grease in the upper drive area used to be a purple looking grease and the grease in the barrel was a different color and weight. If you ordered the rebuild kit with the O rings and bolts I would use it in the barrel (light film coat on the parts )
May 10, 2009 | Bosch Brute Breaker Hammer 11304
Zefal Bicycle Duo 821 XLT  Frame Pumps Logo
705 people viewed this question
Top Zefal Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Zefal Cycling Expert? Answer questions, earn points and help others
