Question about HP Pavilion zt1135 Notebook
Hp pavilion zt1135 won't boot after memory upgrade
I installed 512 mb memory in my HP. It booted the first time and recognized the memory. The computer locked up and I had to shut it off. When I turned it back on it will not load. I removed the memory and it will load now. Can you give me any idea what the problem might be.
Thanks
  • Dan rogers
    Dan rogers May 11, 2010
    are there any other sticks of memory already in the computer?
  • 340 Answers
try to compare the RAM you have bought with those HERE: thise should be the right RAM for your computer.
regards /Teis
Posted on Jan 09, 2009
  • Teis Thomsen
    Teis Thomsen Jan 12, 2009
    NOTE to knotbeerdan
    - I´m not sure, but if you remove the memory board from the easy to
    access lid in the bottom.
    Reboot; and see if you still have memory.
    If - you have memory still, the extra memory board is situated under the
    keyboard.
    There are a few screws in the bottom with an icon looking like the
    keyboard, remove, and then slide the "slides" between the F4-F5 and
    F8-F9 and between F12-Del, careful, the keyboard film is very fragile.
    Here - is the second memory board, - if there is two.
    /Teis
Hp pavilion g7 does not recognize all 8g memory
If only 3GB is recognized it isn't a 64bit OS.
Jul 06, 2013 | Computers & Internet
Upgraded ram 1gb wont boot hp 510 mobo 30C4
If you added another 512Mb RAM to increase the RAM to 1Gb then the new 512Mb memory stick could be incompatible with the original 512Mb or it could be faulty.
Use RAM that is same make and speed as the original RAM.
Remove both RAM and just insert the new 512Mb into your laptop and see if the laptop boots up, if not then the RAM could be faulty.
Mar 02, 2013 | HP 510 Notebook
Very slow 2003 HP Pavilion zt1135 laptop computer
Go to start type
run after that type mscofig after that go to advanced option after that go to boot put there to the last number of prosecor that how you do it
Feb 13, 2013 | HP Pavilion zt1135 Notebook
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
Added more ram but it's not working Compaq E500
what did you mean not working ?? didnt see the new Ram memory ?/ or didnt boot at all ....anyway ...when adding new ram memory ..first thing you do is to remove the Bios battery for to let bios on defaults and let it be able to read the new added unit ....second ...be sure the new added ram is compatible and in the same frequency ,then remove the battery like I said and in the last ...reinstall the operating system ....always look at the boot to see if the ram memory that is displayed is the same value with the one you know that actually is installed on the slots...it should work if this was just an option to make it faster ...and not a wild guess cause it use to have issues and didnt boot before...
Sep 10, 2009 | Compaq Armada E500 Notebook
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Upgradeable?!
RAM - 512 MB (installed) upgradable upto 2 GB (max)DDR 2 SDRAM ( 1 x 512 MB ) that means your laptop has only 1 slot for memory.. ____________________________________________________
Was this solution helpful .Show your appreciation by rating it.
dilipbagdi - Technical Associate
Jun 09, 2008 | HP Business Notebook 530
Hp Pavillion laptop freezes when I install secondary memory
You may not put all together the 256 and 512, the system encountered error when two memory are not equal size and not equal brand.
Either you select 2 units 256 memory or either 2 units 512. or use only 1 unit 512 memory so that no freezes will happen.
Jan 17, 2008 | HP Pavilion dv6000z Notebook
512 Mb memory upgrade
well sounds like compatible issue make sure it is ddr,sdr,ddr2 then check the speed and then checkto make sure that it is pushed in all the way in
Oct 18, 2007 | Acer Aspire 3610 Notebook
HP Pavilion zt1135 Notebook Logo
195 people viewed this question
Top HP Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
