Question about Sharper Image Blue Hat Toy Company Kids Digital Camera
Blue Hat Company Mp3's volume dosen't work
The volume dial has to held down for the volume to be heard. At times you may get lucky and it works a bit but most of the time it doesn't. Any suggetion on how to fix this problem?
  • Anonymous Feb 19, 2009
    Mine too. I disassembled it and there was a wire that had broken loose on the volume knob. I resoldered it but it still doesn't work. :(
You may try resoldering all of the connections on the volume knob circuit board. If one of the potentiometer (volume control) connections has broken free of the board, it may not be noticeable, but may hold the component off the board just enough to cause the problem you're having. If that doesn't help, the problem is most likely in the potentiometer itself, and you won't be able to replace it easily.
(If you are going to replace the whole player, I've heard that the sweetpea 3 is a better device. My Blue Hat is still working after making some repairs, so I haven't tried the Sweetpea yet...)
Posted on Feb 25, 2009
I returned a defective metal detector toy to Blue Toy Company on Friday, October 29, 2010 and it was received on November 2, 2010. Today's date is May 26, 2011 and I haven't heard peep from your...
  • You can try to contact Merch Sourse that owns the Blue Hat toy Company name and see if you get some action there. Here is their contact information.
  • The company that owns The Blue Hat Toy Company is
  • Merch Source, LLC
  • 19517 Pauling
  • Foothill Ranch, CA 92610-2619
  • United States
  • Phone: 1-949-587-9207
  • Fax: 1-949-707-2780
  • Good luck to you.
Regards, Tony
May 26, 2011 | Toys
Where do you put batteries in transforming radio controller car by blue hat?
There is a plastic latch that loosen with a philips screwdriver. Rotate the latch down and you should be able to rotate the top half of the back up.
Nov 20, 2010 | Sharper Image Blue Hat Toy Company Kids...
Need a drawing of the wires inside the Blue Hat Toy Co MP3 player
Try the red on top and black on bottom if that don't work switch them around
Jun 03, 2009 | Sharper Image Blue Hat Toy Company Kids...
Can't erase songs from Blue Hat MP3 &they play shuffled
type the song first letter and u can see title and select the song and go for option and delete it
Feb 24, 2009 | Sharper Image Blue Hat Toy Company Kids...
Blue Hat toy company mp3 player won't turn on
This solution may not make you any happier, but I had the same problem. The issue is that the batteries are not sending power to the player. Before reading any further, check that the batteries are installed correctly. Anywhere there's a spring in the battery box, the negative end of the battery should be touching the spring (negative is the flat end of the battery, not the end with the bump).
If that doesn't help, what I did was to take apart the toy. Yes, this voids warranties, but I'm not willing to spend time chasing down this company for warranty service when I didn't keep my receipt. The small rubber circles on the back of the player cover the screw holes. Just get something under them and pry up until you have uncovered all 9 screws. Carefully open the case. Inspect the wires that go from the battery case to the circuit board, and from the circuit board to the on/off switch. One of these wires has probably come off because it was badly soldered. Either that, or a wire was pinched until it broke inside the insulation. You can usually see where a wire was pinched. Have someone who knows how to solder replace the suspect wires. Once I did this, my player started working again, and now I know the solder joints will all hold for the life of the device!
*WARNING! Only disconnect and reconnect one wire at a time. If you get wires reversed, not only can you break the device, but the wires the company originally used are too thin and can overheat and melt, potentially causing a fire. This is also a reason to be sure the batteries are removed when soldering...
Feb 06, 2009 | Sharper Image Blue Hat Toy Company Kids...
Hover Lites RAdio-Controlled Helicopter
I just bought a hover Lites copter today.(8/22/08) on the bottom of the box is a sticker that reads >> "Please do not return damaged item to retail store. To buy replacement parts, call 1-800-374-2744 or please visit our websites or "
I tried the phone number before posting this and it is a valid number.
Also paperwork indicates the copters are distributed by MerchSource LLC, Foothill Ranch, California
Their info is as follows
For Customer Support,
Please Call Us
at 949-587-9207
or e-mail us at
Hope this helps everyone
Jan 28, 2008 | Science & Laboratory
What can i do is it frozen or what?
Try to restart it and or reboot it you can also let the battery drain completely before you try the first two things. If it does not work, perhaps it is the motherboard that is the problem. Thank you, Connie
Jun 24, 2007 | SanDisk Sansa e260 MP3 Player
Sharper Image Blue Hat Toy Company Kids Digital Camera Logo
224 people viewed this question
Top Sharper Image Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Sharper Image Toy Expert? Answer questions, earn points and help others
