Question about Garmin StreetPilot C330 GPS Receiver
My Garmin turns off by itsself right after it powers up
OK, I am a now gps dependant, and my garmin will not stay on, no matter how long it is plugged in, and the reset isn't cutting it either. As soon as I push the power button, the screen comes on, then turns it's self off...help :)
  • Anonymous Dec 01, 2008
    I have a similar problem. My unit turns off by itself even when plugged in. The indicator shows a FULL battery.
My problem is with humidity or i believe it is. my garmin will turn on however if the humidity is high etc..then when i turn the garmin off it may or may not come back on. if it does great, if not then i have to keep it unplugged for some time9from a few minutes to over an hour) and try to get the A/C to 'dry"it out. It will eventually come back on however it has quit a couple of times when I truly needed it. Good luck with yours and maybe this will help you some.
Posted on Sep 27, 2011
    Scholar:
  • 48 Answers
Sounds like a battery issue in the unit. Are you still under warranty? Also, test the lighter plug for continuity. Vehicles can sometimes blow single fuses that control only the cigarette lighters in the car, and therefore, leave any electronics kind of high-and-dry. So test the outlet first, and if it doesnt function, its probably a car fuse issue. If it does, then you're probably looking at either a wire fault in the plug, or a faulty battery in the GPS unit. For either of these problems, take the GPS in to the retailer, and see if they will work out an exchange or replacement.
Posted on Jun 04, 2007
  • Tristan Noel Jun 08, 2007
    I actually own a 330, they're sturdy units. However, the battery is pretty proprietary. So you can probably get one at a specialty online site somewhere, but I'm pointing to the cheaper fixes. The 330 does not use a cradle mount for charging, the cradle simply holds the unit to the window. The battery is within the unit, and all the wires go directly to said unit. The only reason it will shut off automatically, under normal operation, is if the battery is not charged.
    It's a simple DC in plug, to a standard vehicle plug setup, which, without a working fuse, of course, wont feed power. So if the car's fuse is blown for the cigarette lighters(which is common when using devices on a regular basis, factory fuses are kind of pot metal in most cars), naturally, the garmin will discharge(its lone battery life is very low), and will deactivate the unit.
I was told by the store I took it back to that there isn't a serge protector in this model, so if the engine sends a serge to the gps it will fry it, and I could have had it fixed for 100.00 by sending it in to the company :( sorry , good luck
Posted on Aug 20, 2007
Boy, people are really dumb. The problem the guy is describing is NOT with it's opperation. It's with it's NOT operating when the adapter is not plugged in. It should run on battery for some time afterwards. I have the same problem and am looking for the solution. Thanks for your red herring know nothing suggestions.
Posted on Jul 04, 2007
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuvi® 200 Car GPS Receiver
When I stop and turn off my car, my Garmin 255W stays on. Hows do I turn it off?
If your GPS is plugged into your power outlet in your car, it just means that the power outlet retains power when your vehicle is off as well. Meaning it is not an "Accessory" power source. Not a big deal, simply slide the power button on your garmin unit to the left. The power button is located on the top left side of the GPS. It is spring loaded so when you slide it to the left, hold it there for a second then it will spring back into place. Just release it and the unit should power down.
Jan 04, 2011 | Garmin nuvi 255W GPS Receiver
Garmin is unresponsive. Won't power up or turn
I have a Garmin c340 that would not turn on.
I found the hidden reset button and it works now.
With the display unit facing you, the aluminum cover plate has the the word GARMIN on it. Use you fingernail under the word Garmin and the cover plate comes off. The left part of the cover stays attached to GPS and the right side lifts up exposing the RESET button. I pressed RESET and POWER together and it works now.
Mar 10, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
Feb 05, 2010 | Garmin nuvi 250W GPS Receiver
I have a garmin nuvi 1300 and then i turn it on
it should show "loading maps" try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update, if not contact supplier for fix/replacement
Nov 03, 2009 | Garmin nuvi 1300 Car GPS Receiver
Garmin c340 won't stay on
blown fuse in your power/charging cable
Mar 21, 2009 | Garmin StreetPilot c340 GPS Receiver
Gps will does not work
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Feb 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Powerless Garmin
i think i have the same problem. it shows the boot screen but turns off after about 2 seconds. mine does not work when connected to the USB or AC power either. when i plug it in to the computer, it turns on the boot screen and just stays there. ideas?
May 29, 2008 | Garmin StreetPilot C330 GPS Receiver
Nuvi 200W GPS power supply will not stay plugged in
hpd367 - If your Garmin has died within a year then call them for an RMA number and they will repair/replace it.
Tel 0808 238 0000
Moscow Nell - I had the same problem and got an adaptor from Halfords for about £5.
Mar 27, 2008 | Garmin nuvi 200W GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
4,496 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
