Question about IBM ThinkPad T23 2647 Notebook
2002 IBM ThinkPad T23 battery problems/won't run without power
I just bought an expensive new battery for my 2002 IBM ThinkPad T23, as it would not run without the power cord being plugged in, and this new battery, even after being installed & plugged into a power source for a few days, still does not allow me to run this laptop without plugging in. I may not be doing the right things when I try to use the laptop without an external power source, or there may be some other problem with the computer & not the battery. Thank you for your help.
  • anncos Jan 10, 2009
    I thank Dante777, but I have no battery icon where he said it would be. There is a flashing red battery icon attached to the hard frame of the computer, next to a green battery with a right-aimed arrow in the middle of it and an X after it. These are in the bottom, right corner of the frame of the screen. I did look elsewhere while the computer was on & found the information about my "power options" under "control panel." It says that my battery has zero percent power & is charging. The AC adaptor seems to be working, according to this power option information. I just don't seem to ever be able to actually charge either this new battery or the last one. Hopefully, it's not a motherboard problem, or I'll have to buy a new laptop! Anyway, thanks again - AnnCos
    President:
  • 623 Answers
It doesn't look to me that you're doing anything wrong there.
Was there a specific installation requirement for the battery?
I recently changed my battery on my IBM/Lenovo and all that was necessary, was to let it charge fully before usage.
If you say your battery was charged for "a few days", then I assume there is something wrong with the battery. Next to your taskbar you should see a battery symbol. Double-click on it and you should see the Thinkpad Power Manager. If there is a tab called "Battery Information", see if that gives you more details. Look at the Manufacturing date!
If you really can't run the laptop without being connected to a power source, I would definitely return the battery or at least call the vendor. If your computer is running fine otherwise, there should be nothing wrong with the machine itself.
If you can take a screenshot of that battery information window adn post it here, I am happy to look at it.
PS:
You're doing the right things when you try to use the laptop without an external power source - that's the whole idea, isn't it?
Posted on Jan 09, 2009
  •  C. Dante
    C. Dante Jan 09, 2009
    Hi ancos,
    I did a little bit more research and found this post. End of story: here it looked like a defect motherboard, where the recharge circuits were blown. I really hope that it is not the case with your computer, but you should take that into consideration.
    It would be bad news after all, since a MB replacement can be more expensive than buying a new computer.
    Fingers crossed...;-)
  •  C. Dante
    C. Dante Jan 10, 2009
    Do you have the option to take the battery to another T23 and see if the problem persists?
    That way you could find out if the problem lies within the battery or your computer.
T23 laptop. Put in new battery. WIth battery in
poor battery contacts or dead battery cell doing this flickering
replace the battery if contacts are clean inside the computer
Jul 06, 2010 | IBM ThinkPad T23 2647 Notebook
PC SHUTDOWN WHEN IT RUNS ON AC ADAPTER
HI,
please check the battery of your laptop if it is still working properly or not.
but to make it sure you can send your laptop to a service center to try a same battery first to check if it is the problem or not.
but if it is you need to change it.
thanks,
Apr 24, 2009 | IBM ThinkPad T23 2647 Notebook
Hard drive for ibm t23 /t30 are they interchangable?
Yes you can, the manual says they borh using 2,5 inch ide HDD'
Here is the manual to t23
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/62p9631.pdf
And here is the manual for t30
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/92p1840.pdf
Good luck to you
If you find my answer helpfull, dont forget to vote!
Dec 18, 2008 | IBM ThinkPad T23 2647 Notebook
IBM T23 Thinkpad battery does not charge
If you have some electronic skills and are not afraid to open up your laptop then I might have a solution for this. It could be a known problem in T23 where one component is loosen from the mainboard and in that case it can be fixed with a soldering iron. Other possible cause is blown fuses. But to confirm this you have to remove the keyboard and do the check.
Nov 14, 2008 | IBM ThinkPad T23 2647 Notebook
Batter charging problems
it sounds like a component within the laptop may have failed, that controls the battery charging ,but allows it to run the laptop when plugged in.
unfortunately its not something that can be fixed via text messages, you need to take it to a pc shop to be fixed.
good luck with that
Terry
Mar 30, 2008 | IBM ThinkPad T23 Notebook
T23 wont boot
I would unplug it and remove the battery. Plug it back in and try without battery, if it still doesn't work, unplug the power again and remove the memory (RAM). Plug it back in and try again without RAM, if it beeps then the motherboard is probably good. If you had more than one piece of RAM, try one at a time and see if you get it to boot with one of them.
Jan 11, 2008 | IBM ThinkPad T23 2647 Notebook
Will not boot
Have you tried to power on with the ac power connected.
Jan 02, 2008 | IBM ThinkPad T23 2647 Notebook
Power problem
then the battery is not holding charge try leaving power cable in and switch on
Aug 22, 2007 | IBM ThinkPad T23 Notebook
T23 Thinkpad could not power up
Your machine should run without the battery, just plug it into the power supply. You may check the powersupply itself. Maybe the power supply was bad and not the original battery. You can pickup one at a computer store. A universal costs around $100.00 to $120.00. The power supply is the (usually) the rectangle box that is part of the power cord. Let me know if that was it. Good Luck. Tim
Mar 15, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T23 2647 Notebook Logo
345 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
